As the title says.
I got some from GCG, but they are speedflow/alloy. I'd prefer steel, zinc plated is OK, but stainless would be better.
Nothing wrong with speedflow, just like the durability and hardness of steel.
Before I run up a million dollar bill on std calls, thought I'd ask here first.
PS the oil banjo and banjo bolt from GCG is stainless, so I'm Ok for it.
No you wont. Though it will be tight and you may need to angle the cart slightly to give yourself space to get the fitting on. Mine is angled about 5 degrees anti clockwise looking from the front so the oil fitting clears the number 1 runner on the hks manifold.
But mine has a bolt on adapter to suit the old t3 2 bolt inlet with a 90 degree bend attached to that, and then a male male adapter and then a flexible line so it takes a bit of room :thumbsup:
I don't have water lines so cant help you there, though i figured if i went a water cooled turbo i would just get some earls lines with a 90 on the turbo end and a male male adapter (compression fitting, same as my oil line) screwed into the turbo.
I didn't get the GCG hose kit!!
All I got was the fittings. The oil feed fitting is a banjo and bolt. There is no 90 degree bend, I won't have any problem that I can see. I'll get s/s hose swaged onto the end of the banjo by pirtek/enzed and I'm pretty sure it will fit fine.
The only place I have 90 degree bends is thwe speedflow water line units which I don't want to use, I'd much rather have normal steel banjo and bolt units similar to std fittings.
If your still certain I'll have problems, a pic would be good.
So the water is a 14mm Banjo with a M14 x 1.5 banjo bolt and the oil feed a 7/16 Banjo with a Inverted Flare 7/16-24 Banjo Bolt.
I checked out motorsport connections but they only have the m14x1.5 banjo bolt listed, not the banjo w/hose end its self. Might drop them a line to see if they are available. :S
Im 99% sure ive got one off them before
hey mate iv got some im not using from my HKS 3037 (same turbo your using if i remember properly), cant remember what their made of but i can check out when i get home from work tonight if your still interested
thanks, I'll give them a try. So far, plenty of alloy sfa steel, no s/s.
I can get the bolts in zinc plated [standard] steel, but no web site has what I want. And no banjo's. Pirtek, Enzed, Goodridge, ATP, HPF, and others as well. But you'd have to lay money on someone having exactly what I'm after, I'm just not looking in the right places.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
