  • Replies 98
2f2f was f****** awesome!
not happy that they dumped the jap cars for the american crap
...and that scene where they dragged the american crap for pink slips. not happy how they depicted jap cars as heaps slower!
And another thing... if that were real like there is no way anythign would keep up with that r34 GTR!
still a great film and even better than the first one!
Waz.
https://www.sau.com.au/forums/topic/17575-2f2f~/page/5/#findComment-366331
the movie was no where near as good as the first!!!!!
to much plot and not enough car and action seens, the cops should of fixed up his r34 and given that back to him to drive instead of that evo.
it definetly needed more of the r34 in it.
https://www.sau.com.au/forums/topic/17575-2f2f~/page/5/#findComment-367479
Well I just 'HAD' to see this movie. I didn't expect much and it didn't even meet those expectations. Now i had just watched Ronin for the first time the same day - there is some awesome car action.
2F2F was the biggest load of crap I have seen. In between the crappy storyline there are some nice cars, although way to ricey. But you get the feeling that in all the go fast scenes that they do them at 20kph and they just sped up the film or use special effects to give the sensation of speed.
A little less footage of clutch pedals and hands on gear sticks and a little more REAL car action please.
There is just too much wrong with this movie. I feel guilty that I have given the producers my money.
WTF is the deal with pink exhaust flames.... are you serious? thats sooo dumb. 1 car jumping another? soooo dumb.
The white guy lead actor is a loser. I hope I never see him in another film.
https://www.sau.com.au/forums/topic/17575-2f2f~/page/5/#findComment-371737
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
