  • Replies 190
**JaR** you'll have to forgive ppl its teh internets ppls only have a 5min attention span
sorry great sig madaz
Edited by R334door(s2)
List has been updated in the first post.
The following are no longer guaranteed a speedo as they have failed to pay or contact me.
EVL-R33
DaGr81
DazWah
JeaneenGTST
As there are only 3 spots remaining, the first 3 to pay will secure a spot. Any new comers wishing to get in on the group buy will also have the chance to take 1 of the 3 remaining spots if they pay before those listed above.
latest update from Amec
the template that they use to manufacture the gauges has only just finished being produced so probably still another week away, I will contact them again next monday.
Still 2 spots remaining
Much longer too wait mate? :wave:
What ever happened to the R32 ones? too hard basket?
yeah i asked Amec about the r32 for my mate something to do wih the speedo cable box at the bak ove the cluster they havent worked it out yet how to calibrate to 300kmh just look for his post pm him for the info hes great help!!
:sorcerer:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
