Did you have the car compression and leak down tested before you purchased it?
ALWAYS have your car comprehensively checked before buying it, by a workshop that knows Skylines back to front and will go over the car with a fine tooth comb to make sure you know exactly what you are getting yourself on to.
If the compression is only 75 on number 5 , leakdown would be like 75% on that cyl. What was the leakdown results on all cylinders? It could be any of several causes for the low comp or even a combo . If i was a betting man I would say broken ringlands on 5 but it could be a leaking H/gasket , valve..... A leakdown test will pinpoint it if its bottom end or in the cyl head .
As it is not a 10 year old car yet you are covered by consumer law for 3 months in NSW as long as the car has less than 100 k ks on the clock. Unless they can prove that you abused the car of played around with it , they will have to repair it as it is not normal wear and tear ...
One cylinder down to 75psi in a turbo car will not make a huge difference in power because when under boost that cyl is firing . Its like having a 1/12th power drop as that cyl only gives you half the power than it would normaly would . You should be able to pick it up when iddling because its not firing properly until it starts boosting .
compression of 75 is about 50% of what it should be, not 75%.
not to be picky but looking at the dyno, 1 its in shoot_6 not shoot_6F and god damn good intercooler for Intake temps of 14 degrees, i think best is just get them both done again at a reputable place, isn't there 2 types of compression tests??? wet and dry??
Here we go again .. Who said anything about compression being 75% dude ... I said LEAKDOWN on number 5 would be 75% . There is a difference just in case you didn't know ...Leakdown is measured in % of pressure lost and I said having 75 psi in number 5 would resalt in a leakdown of 75% .
well sorry captain keyboard mechanic.
Yea , maybe better to stick to the wastleland !!!! I guess if you just sit back and read .... you may learn from others that have some idea at what they are posting.
and that some people are so far up themselves they are inside out.
I wouldn't expect anything else from you dude .... This is the reason why you have no idea what you are talking about ...
I'll say it again leave the technical stuff to others .... stick to the WASTELAND, it suits you......
If you had a leak down test done pre purchase and it was good then you may want to read up on what it is you tested before jumping the gun based on a compression test result.
You will not make 200rwkw on 12psi if one cylinder is bleeding off pressure.
I suggest 3 possibilities, 1) it's a dud compression test, 2) Your initial leak down test was dodgy, 3) you've broken the car between your initial leak down test and the later compression test.
If you take the car back to E&M to be checked and it shows all good, you will be charged for it. If it shows up bad, then make sure you are familiar with your warranty conditions because you had it independently tested, and it was good when it left the lot. You've played with it in the mean time. I think you will lose if it goes before a judge.
Not trying to be harsh, but seriously, find out what you tested pre purchase before going any further.
They did a leak down test. I just read it again in the morning.
I'll go home and re-read the details but they "said" that they did.
And what do you mean by played with it? I didn't add any parts to the car or tune the engine.
Just got a power run on the dyno and a comp test performed.
And i aint jumping the gun. Just being cautious.
And doesn't matter if it does sound harsh...i don't want to be treated like a bitch. I want the truth.
Im with Dave. Now that you say you had a leakdown prior to purchase and all was good there's not really much you can do.
Have another comp test done; chances are the test was a bit bogus. How many times was each cylinder tested, should be seperately tested at least twice if there's any funky readings.
If it has lost compression all of a sudden it would indicate detonation and smashed ring lands in that cylinder.
It is making 200rwkw on the stock ecu with 12psi so really it is quite highly strung. That small SMIC would heat soak fairly quickly after a hard run, keep your boot in to it and it will rattle its head off. The knock sensors only protect the motor around peak torque, high rpm the ecu ignores it.
I have a Frontmount IC. And each cylinder was only tested once. Except for cylinder 5. They tried it 3 times.
also if it was that low in compression in 1 cylinder you would be using a touch of oil and it would blow a bit of smoke when you got into it a bit. get someone to follow you and then give it a good bootful through first and second. if there is no sign of smoke it make be a dodgy test. if it does blow white smoke then the test is correct.
I always have a whitish smoke in the rear. But this is when i start up in morns or even in afternoons for the first time. Will definitely get someone to follow me.
If it is blowing smoke, what does this mean? Dodgy pistons/cylinder rings?
Didn't know i could take it to other workshops...now i know :D
Don't think i have the results of the leakdown test. I need to go home and check.
And the car has statutory 3mths warranty + extended 2 yrs.
What is the difference between shoot_6 and shoot_6F? And the intercooler is a front mount so that is why it has low temps??
And isn't Advan Performance and CRD a reputable workshop?
Edited by Fujiwara
That white smoke could just be condensation, hop out of the car and look at the 'smoke' when the car is idling, if it dissipates (think of steam coming out of an iron or pot) then its condensation, if it hangs around and floats up a couple of meters then you've got a problem
If you're going to correct someone so strongly you better be right. Wrxhoon quite likely has more years experience with Skylines and cars in general than you have been alive and you're calling him a keyboard mechanic?
We're all here to help and be helped. Spouting incorrect crap does neither so best to either keep it to yourself or preface it with, "I think..." or better, "I'm probably wrong but...".
Ok...
E&M didn't reply to the 2 emails i have sent.
I received read receipts for these though...
Anyway, i took it to CRD.
All cylinders are fine.
Possible cause is carbon build up and the piston rings weren't sealing properly or something.
Cyl 1 185psi
Cyl 2 175psi
Cyl 3 180psi
Cyl 4 175psi
Cyl 5 175psi
Cyl 6 175psi
So now i can start doing some work.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
