All,
After thinking long and hard over what new car to get, I have decided to stay with a GTR, Im keen to do some more serious track times so I am looking at an R32's GTR, which I can take one step further then my R34.
I have found a real (Checked with Nisan) R32 GTR Vspec 93 model 77,000 Km, mods are listed below.
HKS 2540 turbos
HKS 264 cams
HKS Turbo Manifold
HKS Dump pipes
HKS Header pipes
HKS Inlet pipes
HKS Pods
HKS Intercooler
HKS Hyper Damper Suspension
HKS Remote oil filter and cooler
Adj Cam sprockets
OS Twin Plate Clutch
Metal Head and other gaskit's
Apexi PFC and hand controller
Upgraded fuel pump
800CC Injectors
90mm exhaust
Cuscal Remote catch can
Cuscal radiator deflector
17in Advan wheels
Caster Adj front
Boost gauge
Turbo timer
The Vspec STD Brembo Barkes, Vspec diff and Brake vents
UAS Dyno showed 280KW at 15PSI (With 2.5'' crap Cat) and Comp check was approx 140PSI on all 6, under carriage is a straight as they come and the interior is in good condition.
I plan to do some additional mods.
Water Menthol injection, Fat belly Cat, RB25 Airflows and pods, Sump Baffle, DBA rotors and Frodo 2500’s, Upgrade the radiator, Camber kit and alloy bushes, Retune.
Buy price is $25K with 12 months rego.
What do people think about the car and the price?
Im thinking of placing a deposit today, so appreciate the feedback.
Thanks
https://www.sau.com.au/forums/topic/176091-ozs-new-gtr/
  • Replies 86
That is the intent! Im moving work location and will be doing far less street Km's so I can allow this car to be a lot more aggresive then I have with my previous GTR's.
I guess my question is around market price for a car like this. The ass has dropped out of the market a little, and I wonder if I am paying too much for this car?
https://www.sau.com.au/forums/topic/176091-ozs-new-gtr/#findComment-3222957
Hey car sounds good, price sound close to being right possibly a little high.
I know godzl1975 is selling his car on the quiet and i was very tempted to buy it but i didnt have the bank to support it in the long run.
His car is unbelievable! You should check it out.
https://www.sau.com.au/forums/topic/176091-ozs-new-gtr/#findComment-3222963
Thanks, car looks good, I have sent him a PM for his number, so we discuss.
https://www.sau.com.au/forums/topic/176091-ozs-new-gtr/#findComment-3222974
so who put the metal head gasket in? was it done in aus? were any other internals done?
with those mods and shitty looking wheels like that tells you the car wasnt sitting in a show room.
my money is on it craps itself before the 100k service..
my opinion is to buy a gtr with great body and screwed engine for about the $15k mark and use the 10k to rebuild your own engine..
that way you know what you've done to is and work has warranty (to some degree). also the car feels more like your own becaause you have decided what you want from it.
only dis advantace is that you wont have the car for a while while an engine is built.
thats the way my brain works ;)
https://www.sau.com.au/forums/topic/176091-ozs-new-gtr/#findComment-3223159
The car looks to have had the work done in Japan a fair while ago, except for plugs its as it left Japan.
I started with that mind set, accept The parts and Labour bill hit almost $20k (Internals/turbo's/clutch/ and acc's), and I have had trouble finding cheap late 32's without damaged or rusted rails. I have only been looking for 3 weeks both here and in Jap auctions.
Point taken but I have run out of time. I loose the 34 in a couple of weeks and need wheels.
https://www.sau.com.au/forums/topic/176091-ozs-new-gtr/#findComment-3223203
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
