I have reached my quota for pulling or putting in GTr motors this month sorry but will be happy if you bring in the beers to work and I will support you from here ???? :D
"No Beers for you!" (Sounding like the soup natzi)
  • Replies 86
we drinking beer we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
we drinking beer
watch me dance!
Well everything went great, started at 3pm on Friday. Keil arrived at about 7 abo bob at about 9pm. Engine out at and sump off by midnight. Up early and over ro UAS by 8 drill out the sump return and fit sump baffle into clean sump home by 10. Fit new cam belt and pullies, inspect #6 bottom end bearing, all good. Fatz arrives at 12, beer consumption increase work output decreases. Fit new eng mounts, fuel filter, radiator, plugs, inj seals, camber kit, rotors, pads. Eng back in by 4pm. 9pm eng started and bleed water system . Only issue 3" cat did not fit, looks to be R34.
Great job by everyone. 2cases of beer gone and one ready to track GTR.
kyles a champ isn't he....
Yes he is the man, worked like an animal while faz drank all arvo. Thanks for stripping the TRKBCH. Your offer on the eng hoist is appreciated but its a little too late. I now have the SAU one at my house if anyone needs it.
there was alot of crack dealing doing on at this GTR showdown!
those wife beaters rocked..... and lucky someone remebered to pull the rag out ofthe turbo!
mmmm beer!!!!!!!!!!!!!!!!!!
Perfect work fatz. Leaving rag's inside the inlet and bolting on inlet piping!
Mental note to self, dont let fatz drink and work on the car!
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
