Ermm
Ever since Ive had the car arrive from Japan, the steering has been very very heavy. @ all speeds. It's great for draging at WSID but shitty for windy roads and roundabouts!
Ive gotten used to it but it's pretty annoying now and then..
So what's causing this? (Ive had a search but nothing definiative with a solution.)
1. I think their is enough fluid in there. Not sure have to get it checked out.
2. The steering fluid box broken?
3. Speedo works.... pfc say the pump is working but I dont have the speed reading on the pfc (Only rpm, think the speed wire is cut at ecu wire loom)
4. Blocked lines?
5. Broken power steering?
Can anyone help?
Yes it's not just me other people say my steering is heavy, even Abobob said so! So must be heavy!
https://www.sau.com.au/forums/topic/176264-power-steering/
i would look at correcting this. you may find it magically solves your steering problem. also look in your power steering fluid resevoir and see if there is any fluid in there would be a good place to start.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3225633
Hmm yea Ive been meaning to rewire the ecu. Been lazy for last xx months lol
In the resevor you are suppose to see fluid? Because I think I see some well according to that little guide under the resivor cap it says it's full... hmm will check this on Saturday when there is light.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3225925
nope HIcas light is off... Ive only seen it go on when I had water in my coils and car was jerky.. So I dont think it's the hicas.
I do have power steering but just very stiff like my steering is on viagra or something :)
It may be the speed wire, as Duncan/Richard has said which makes sense ey. I'll have a look at rewiring it soon...
Hopefully this fixed means I can go drift around round abouts weeeeeee lol :)
I'll report back when Ive done the wiring fix!
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3228524
So anyway didnt need to rewire the speed wire, it had one of those connectors..
Now my pfc controller tells me what speed im not going! Didnt happen before.. lawl.
Also checked the resivior and it's full.
Perhaps it maybe the steering line or something blocked in the lines. or maybe the pump is dieing?
go to the gym turd!!
LOL :P
Maybe i'm paranoid, but when I move the steering on Missturbos car and also drove Haysey's car awhile back and it is ALOT lighter than mine! Much like how the rolla steers.
Could it also be the tyres i'm running? larger tyres? But this shouldnt be the case.
dammit! :D:happy:
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3228838
Stupid question..
I suppose you would notice the boiling temps by now..
But if your power steering belt the right size/tightented/not too tight?
Is there enough Power steering fluid?
Pump working?
All hoses connected?
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3231394
  • 2 months later...
having the exact same issue but with the HICAS light on in my r32 GTST
Speedo not working - RPM working
steering is really tight at low speeds
getting it looked at soonish.
any idea how much it should be to get this fixed?? anybody ?? :P
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3359633
I got this fixed...
Problem was...
Power steering pump, the filter was being clogged and hence lower power steering pressure and also it was leaking. Got it reconditioned and car is like a brand new car, ive never driving it with such ease.
Also the soloniod at the steering rack was not grounded properly (not sure what this does but I assume it's the >100 speed to make the steering slightly heavy when at high speeds). Because I notice now that at low speeds steering is easy, then as I get on the hwy the steering is heavy abit to counter the light steering.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3361387
I got this fixed...
Problem was...
how much did it cost? or did you just do it urself?
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3361430
any idea how much it should be to get this fixed?? anybody ?? :D
Your speedo cable is broken. get a new one and install it and it will fix all your issues.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3362014
I got this fixed...
Problem was...
+1 on how much...?
been meaning to get this fixed on my car too - i can see if leaking from the p/s components above the rubber sleave on the drivers side.
https://www.sau.com.au/forums/topic/176264-power-steering/#findComment-3363946
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
