Wow.. i thought it was really rare to still have a boost restrictor still in place. I heard they have a yellow band around the hose where the restrictor is.. did yours have this and is it obvious? Where was the hose?
I dont think you will have any problems. Ive got a 32gtr and i couldnt find this boost restrictor so I assume its gone and car runs perfectly fine. To my understanding, the car was designed to run the full boost anyways and it was just one of the ways to reduce the power to 206kw for japan. saying this.. im not a trusted source of info so maybe someone else can confirm
I had a search here and basically everything i said was wrong.
Im assuming now that my restrictor is still in there somewhere. I might look for it tonight.
So yeh, running more boost means your giving the turbos a tougher time. You dont want your turbos to shit themselves thought as the debris from a rooted exhaust wheel could damage your engine.
from memory there are two hoses coming off the "boost soleiniod"
about an inch down from the soleiniod on one of the hoses was a yellow band of paint (0.5cm thick),
i squeezed it and could feel something solid was in there,
took me 5mins and i am no good with cars
It dose seem to make a VERY loud rush of air sound at boost.
dont know how normal that is
I will take it to cruz this week and get some more advice
that is if no one knows what i mean about the sound
Edited by Y2K
yep thats the hose to pull the olive out of and always will give you a dead accurate 14.5 psi, the turbos are fine on that boost if they arnt in to bad condition, just make sure if you have a computer to get it tuned
If i only have the stock computer will i have problems with the engine running lean
yeh... but now with 14.5 psi, things might be different.
maybe the fuel pump isn't up to the task?
I was mainly refering to the thread owners.
but if you have gone from 10 - 14.5psi, it's be worth re-checking surely.
it's not like it's cheap to build these rb26's... even to stock level...
$50 is cheap insurance and piece of mind.
if I ever get an RB26 powered car, it will defeinitely have a compression check, leak down test, all new fluids, new plugs, and a dyno run.
a little outlay up front but good cheap (in the grand scheme of things) insurance.
OK dyno is booked for AUG 1st (he will do all combinations of equip eg with out boost restricter, put boost restricter back in and combos with anything else getting put in) so i will post results incase people are interested
It was also mentioned to me that changing the cam sprockets
would be a good AND gentle mod to perform
What say ye SAU
nah man it's just the GTRs i think
my R32 GTSt and GTS4 don't
R33's done either, they do have a solanoid you can put a switch on though and run higher boost at lower rpms(33s have a controller to run 7psi at below 4000 i think it is, then switch to 10psi or whatever it is standard)
you could also look out for a bleed tap, there is an article in the DIY section i think about a ball valve type bleed valve, which is meant to be an excellent controller :) and a lot of people have thrown away(well sold) there electronic ones and replaced it with the tap, it only costs round $22 as well :D
the main problem you will face now is keeping your license intact...enjoy! Standard turbs will last fine on 12psi (except maybe extended track use)
niggah wot?
i spent 2 years thrashing my standard turbo 32 GT-R at just over 15psi (including 4 track days) and it was still going strong, lol
I removed my boost restrictor almost 2 yrs ago, runs 14-15psi (up from11) and no dramas. power jumped from 198-230rwkw with just addition of apexi panel filter and removal of restrictor.
So no aftermarket computer ? When you run it on a dyno were the fuel mixtures within range?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
