i keep getting beaten off the line in drift comps by cars with bigger tyres and less weight. does anyone have any set up tips for my r32 to help bridge the gap?
p.s. gtst-310rwkw
hsd coilovers
rear toe-1 deg in
rear camber - .75 neg
standard swaybars
standard rear cradle bushes
Edited by DRIFTER
https://www.sau.com.au/forums/topic/176337-getting-a-drift-car-off-the-line/
i'm guessing your problem is mostly caused by wheelspin due to a very peaky power delivery?
you could always try loading the old clutch against the throttle just before the flag drops, and slipping it a bit on take-off
(p.s will obviously be harder on the clutch though)
how about a variable boost control system for lanches like AVCR has 1st gear 5psi 2nd 10psi 3rd full boost etc
need to have it setup so you can easily switch it back to normal mod after the launch though
how stupid is it that in D1 you would never have this problem as the drivers keep pace with each other rather than have a drag race at the start
ps get swaybars and the whole rearend adjustable setup .5 deg neg on the back would help a little bit to
the other items might not help but Im supprissed that with that much grunt you havent covered the other bases first
pps engine mods list please
Edited by 1400r
yeah as above.somthing with launch controll.
cant you just feed the throttle?
it's all got to do with suspension setup.how much camber is on the rear?having different spring rates help launch also.bigger tyres are a good start as well..
ps:were you at the last fri night off street drift meet at OP?
nath, you need to work your spring rates into it also, but I was running +0.5 camber on the rear with -1deg toe... always hooked up with nearly 800nm torque.
just a thought mate.
sounds like congrats are in order dan. i didn't think i'd be seeing you out on the track this year. what happened to scott? do you think you can make that thing slide? will you be changing forums? :laughing-smiley-014:
I would look at your dampers and springs. also look at adjusting the traction rod to place the rear upright more upright. and better tyres also.
thanks for the reply, i'm hopefully going to borrow some softer rear coilovers to try, can you elaborate a bit more on what to do with my traction arms? should i change the angle of the rear cradle using bushes? thanks in advance
LOL, no staying on here mate, I love this place! Thanks for the congrats, I didn't expect to be back this year either.
Scott left the team for reasons that I'm not too sure of, you would have to ask him mate.
As a result I got an invite to test the car, and it turned into a drive.
The Car has plenty of potential, and it has improved with just a little bit of testing, but there is still more to do.
I was able to slide it from bridge to bridge at OP, so it can be slid, and it has got the gear there to get going.
well depending on how they are set-up now lengthening the arms will position the upright more upright and give more traction. using cradle bushes you can angle the subframe for more traction (squat basically) most of the people that sell the subframe alignment bushes have a diagram that shows how to position the bushes for different results.
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
