I bought my car from a dealer + when he explained the security in the car he said he'd left the stock immobiliser in + added the proximity sensor immobiliser as well, giving me 2 different immobiliser setups...
If I don't hit the 'unlock' button on my key remote, the car won't start. It'll keep turning over, but refuses to start. It self arms this as well. If I turn my engine off + don't lock the car, I still need to hit the unlock button to disable the security + start my car.
And of course if the proximity sensor isn't next to the ignition, the car won't start.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3611471
So the factory alarm is supposed to be stripped as part of compliance? If so, what is the little fob thing on the key chain for, and also the sensor looking things on the dash? Do they do anything?
who did the compliance on it? if ISASO then it was me that removed it. I've had 3 of them disable 3 cars on me so when I do the compliance immobiliser them they come out. its not factory anyway. they are dealer fitted and some of them are barely fitted. most are in with scotch locks and they are ALWAYS loose.
the black tag on your keyring(autowatch badged) is the Immobilser. two pt std issue. the round thing below the boot release switch that looks like something pushes into it does nothing.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3612926
hey guys,
just a quick note about the adr82/00.. if the vehicle is fitted with a factory immobiliser there is a way around having to replace it
dotars recognise the ULC-S338/98 which is the canadian standard for immobilisers (all vehicles in canada must be fitted with an immobiliser whether stock or aftermarket)..
The ULC-S338/98 does mention the Infiniti v35 so all you need to do is prove to dotars that the v35 and g35 have the same immobiliser (which you can grab of the Nissan Fast system)
We have been using this evidence for most vics and dotars have never questioned it...
hope this helps
cheers,
k
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3613715
I'll apologise in advance for my lack of knowledge both in this area, and cars in general. So I have the keychain thing, the two sensors on the dash, a small light just under the clock that flashes once the keys out of the ignition, and a red light labelled "Security" to the right of the steering wheel. Do I have an immobilisor or an alarm, and if so, how can they be activated?
Also, I got the car from a dealer in Sydney who do their own compliance.
Sorry again, this isn't really my thing! If I was in Brisbane, I'd be over seeing Chris Rogers already!
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3615516
word of advice- leave it all alone. if you activate it by mistake (IF it works- see other post ) then you have stranded yourself. if you have the nissan branded tag press it into the slot below the steering column. that will activate the dealer fitted alarm. the OE one 1s self triggered. the autowatch one is the same.
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-3615654
  • 4 years later...
any of the alberts stores. see cannington and speak to pete. get them to toss a autowatch 446 P in it.
Hi Chris,anyone you could recommend in Melbourne?
Edited by rawzz_v35
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-6401388
ok so stopped down at Alberts today. They are going to put in a slightly different system that runs off my car key. $550 installed.
Sound about right? I asked for the Autowatch 446 Premium, but Pete was talking something slightly different.
Once its booked in, I'll let you know exactly what it is :)
Thanks again!
https://www.sau.com.au/forums/topic/176463-alarm/page/2/#findComment-6405179
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
