QUOTE(leb @ 16 Jul 2007, 03:02 PM) *
mmm so if my rings for my pistons were gone it would blow smoke out right from the exhaust? oh well guys mitchy has stepped out and confirmed that my engine has 165 compression for all 6 cylinders then the engine should be fine....im goin to go remove the stud and fit a dip stick in there problem solved thanks guys for ur support sorry to create a thread that was kidna like days of our lifes smile.gif
Cheers
Chi
Somehow dont think he meant your car dude lol
  • Replies 87
There was no dipstick when Mitchy bought the motor, that is why he got the compression test and leak down test done!
NO explaination because you've never asked, and we don't know why either... only that it was built by Ray Ferrari (look him up and ask him yourself)
Mitchy does know what compression his motor possessed...as said earlier, he got it done because he had no dipstick.
This may sound odd, but if I bought a motor with no dipstick (like mitchy) then I would replace the dipstick, not do a compression test. It's like saying my car had a no radiator cap so I got the boot lid tested for paint thickness...
perhaps if ol' mitchy had just replaced the dipstick when he bought the motor (which would have been the smart thing to do) none of this episode would ever have happend.
4.5L oil sounds low.
mine gobbles around 4.8L , more soon when the Grex oil filter relocater is fitted.
get a dipstick fitted !! surely wont be expensive. dont delay. compression tests are cheap, all up (test and fit) what a $300 job tops?
oh, and its pretty farkn easy to see if a turbo has been installed properly or not (ie no copper washers etc), visually and by feel, plus the turbo oil feed pisses out oil straight away and can be easily heard, engine sounds all "liquidy" (been there done that with my highflow, one bolt wasnt quite tight enough and out came some of the engine oil).
my advice - get a new mechanic! definately.
nah man, buyer beware. pretty easy to visually "see" if there is a dipstick. how can you NOT notice ?
  • 6 months later...
I got an rb25det off a mate for a conversion into an s13 and the dipstick is on the wrong end of the block.... its on the rear of the block and the other hole where the dipstick used to be just has a bit of bolt in it. When i put the dipstick in it just hits the sump.... a bit stupid IMO.
well that would depend on what the motor came out off
if the 25det was in a 240z then thats where it needs to be - as they are rear sumped when the conversion is done.
funny old thread to resurrect
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
