Hey guys,
Long story short: I own a R32 GTS4 rb20det moderately to highly modified, about 2-3 months ago i damaged the engine, we think its a head gasket but havent pulled it apart yet. I have been more keen to get my RB25det in! So anyway, when i blew the engine a few months back, we rolled it and stored it at a friends place near by. Last night we were finally able to bring it home!!! so happy to see it again!!!!!!!!!!!!!
ANYWAY, the rb25 hasnt been rebuilt or anything it came straight out of a staggy half cut with low K's so im keen to just throw it in. But there is one precaution i would like to take and that is replace the OEM head gasket with a metal one to help prevent blowing another one too soon. This will be done by me and a friend so just wondering what were the 'technical' aspects about this project... ive heard you have to undo the bolts in a certain sequence to prevent bending the head as it comes off? Anyone know this sequence?
Any extra info would help :blink:
Cheeeeers
https://www.sau.com.au/forums/topic/176583-my-baby-is-home/
cheeers guys! ripped the RB20 out this morning! so now its time to start preping the rb25 for the drop in.
I dont want to push anything over 240rwkw now as i want to keep a bit of reliability/streetability, id be more than happy with the more responsive and torquish power from the 25 after driving the 20. All the parts i have are interchangable between the engines except for: Jun front fed Plenum, custom fuel rail, and GTR injectors. Trying to figure out if i should go stock 25 plenum and pay for extra cooler piping or buy another front fed plenum to fit the 25...
So now its time for my shopping list... Would love for some input. (Trying to keep to a budget and only getting what i NEED for this to work.)
The RB25 shopping list: (So far...)
- Head studs
- 555cc nismo injectors
- Metal head gasket (What size is recommended for say 14-15psi of boost.)
- Gasket kit
- New belts
- New hoses
- Oils and fluids
Edited by zertek
https://www.sau.com.au/forums/topic/176583-my-baby-is-home/#findComment-3230470
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
