Just posting up about last week at wsid.I had met quite a few of the skyline forum members down there s the tyre gauge I lent out sparked up conversation everywhere. I only go twice ayear to the drags and I ended up popping the 0.000 reaction time and ended up taking home $960 dollars. I didnt even know there was a prize for this..I am still amazed!!
Btw very nice to meet you guys there the other night cheers
Stav
yeah
the timing equipment at WSID is obviously better than it was at the old Creek strip, because i seem to remember any better than a 0.004 at the old track was classed as a redlight.
yeah
I have heard this too.On their website of wsid they actually have an article before the night that it is the quickest reaction time without crossing the red.This must mean that they know if I had run the red!!Which obviously I didnt.
http://www.wsid.com.au/default.asp?Page=Article&ID=647
Edited by useless
60 footers went to buggery 2.486 to 2.9 . Standard ones do 2.3 lol. As a result the et wasnt good at all. The wagon had no traction whatsoever.I had taken it out to see where its at. Last year it ran a 14.7 .It has more power this year but just cant get traction. Today I treated it nicely and installed some traction enhancing parts.The takeoff has dramatically improved.The rear leaf springs are not flexing at all.
The last run of the night and no final timing board.Tyre pressures were adjusted and the car recorded a 2.109 60 footer 6.088 330 footer and 9.335 660 footer.This run was on par with a 14.5 1/4 but never got recorded.But it happens and I still had a great night.
Edited by useless
at willowbank a perfect reaction time is 0.400 cause it starts timing when the last amber light goes off. this is taken from the willowbank raceway website
It measures the time from when the last amber come on to when your front wheel clears the start line beam. Now as there is exactly 4 tenths of a second between lights, it then follows that a "perfect light" will be four tenths of a second - meaning that the vehicle has cleared the stage beam at exactly the same time as the green light came on. This is shown on the time slip as .400. Anything less than this means that you left too early and red lighted (fouled) and any more than this is wasted time sitting at the start line.
Stav
hey mate i was the guy in the black 32 that borrowed ur tyre pressure gauge.. congrats on the reaction mate.
Hey mate how are you? I went last week and got a pb of 14.5 95.68mph. For a na six au taxi wagon..I was stoked!!
Btw I didnt know the darn gauge was faulty on the night ..I am sorry:(
Also wsid do have the best timers and they also register red light breakouts.It was not a breakout.
Edited by useless
new pb thats good. i should be heading out in bout 3 weeks or so with some new upgrades... thats one quick taxi
HEHEH Its not too bad .i did 90% of the work myself and had Croydon racing tune it. It isnt running 100% as it needs the diff gears and a few things I have touched retuned. I would love to run a 13 na but thats another story.
Good luck in 3 weeks mate:) :P
Edited by useless
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
