yep top racing i think it is!!! They are always first to be mentioned... Any idea as to the labour cost to rebuild my engine? Just a rough ball park for me to work with.. This includes fully prep and balanced bottom end.
I know a guy who told me he spent over 40k having an RB25 built there... could have had an OS giken 3L for the price he paid LOL
but seriously, why are you having your engine rebuilt? seems alot of people who spend big $$$ building an engine that only does the work a stocker can handle
but hey, its your cash.
https://www.sau.com.au/forums/topic/177011-vision-r/#findComment-3238859
agree 350hp stock internals, 150,000km :D still going hard! and ready for more boost
https://www.sau.com.au/forums/topic/177011-vision-r/#findComment-3238868
