Here is a Radar Detector that is no longer needed as I bought a couple of years ago when i was a hoon but with new laws wont even bother to use it and have no use for it still works fine comes with all attachments and wiring necessary for it to work ........just dont get caught with it.......... sell for 300
Edited by wrxxy
https://www.sau.com.au/forums/topic/177148-fsradar-detector/
  • 4 weeks later...
how well do they work mate? i.e do they tell you like 200m away there is a radar ahead? or only when you're pretty much on it? and dont you have to sit them on the dash or something? making them real obvious?
Cheers mate
On your windscreen up high with suction caps and have hard wired or into cigarette lighter plug.
For radar guns it works from far coz radar gun have strong signal, but for speed cameras it only works from few hundred meters enough time to slow down coz speed camera very weak radar signal.
In any case when it beeps or starts going troppo slam the anchors on as they (the police) need to have a bit of time to lock you in.
Edited by wrxxy
hmm.. Ive accumulated 12 demerit points.. im on probation for a year. I wonder If this thing would be a smart buy? considering if i screw up once, i loose my licence for a year. what do u think?
Slow down and less burn outs? :D
Cheers mate
I think you will find that every state use's laser guns now, laser guns do not put out a signal untill they pull the trigger (unlike radar which is always putting out a detecable signal) so unless you are near another car that they are targeting you will not have any warning.
if you download the 3rd image with the brochure you will see that it detects radars & lasers
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
    • If you are getting that sort of fuel usage, you might as well be back in the stagea
    • Looks good mate, those stainless lines must be a bastard to do neatly. Better get it to a track again sometime soon, I'm doing to Wakie day next Wednesday to see if the v37 likes cool weather better than hot weather....
    • If you've got spark, and you've got fuel, it needs once last thing to go vroom... Have you compression checked the motor?
