Hi,
PICS: http://www.thegodzilla.com/car-parts-for-sale.php (scroll down)
Item: RB26 Sump/front dif, complete with Tomei baffel kit.
Description: good condition, comes with Tomei sump baffel kit installed.
Price: $520
Item: New RB26DETT Head Gasket
Description: Brand new Nissan head gasket to suit RB26 motor
Price: $50
Item: R32 GTR Standard front pipe
Description: Standard item, few scratches.
Price: $50 $20
Item: Highmount manifold for RB26
Description: Cost $1200 new... Still basically new like everything else. The wastegate flange has now been cut off so you can have one welded on to suit your wastegate.
Price: only $770
Item: Custom intake for single turbo Rb26
Description: Looks great. Made at Godzilla Motorsport. Comes with silicon hose and clip, ready to instal.
Price: only $170
Item: RB26 Big end bearings - Brand new.
Description: New, in box. Cost $85.15 new
Price: $60
Item: RB26 Main bearings - Brand new.
Description: New, in box. Cost $173.80 new
Price: $135
Item: Exedy Clutch
Description: From my R32 GTR. I had this clutch installed before it went on the dyno. So has done basically no kms.
Price: $700
Item: Revolution Billet Flywheel
Description: I go tthis at the same time as the clutch.
Price: $170
Item: 82ERK Number plates - BZERK
Description: Never fittd to a car, Never registered. Navy blue writing on a silver plate.
Price: $900
Item: HKS Pod filters
Description: Nothing wrong with them at all
Price: $110
Item: RB26 Alternator
Description: RB26 Alternator in good condition
Price: $100
Item: RB26 Water pump
Description: Bought it for rebuild, used only for short time on dyno
Price: $100
NEG on some items
pickup can be made from bulimba or bracken ridge.
parts can be sent Australia wide.
regards,
Drew
https://www.sau.com.au/forums/topic/177175-gtr-parts-aftermarket/
pics of everyting here: http://www.thegodzilla.com/car-parts-for-sale.php"" target="_blank">http://www.thegodzilla.com/car-parts-for-sale.php
i am neg on most prices.. just not the brand new stuff like bearings, head gasket...
I'm interested in the manifold.. a few q's
who made it? chinese? japanese? australian? brand name?
what material is is made from?
is it just the wastegate flange that been cut off or the pipe?
Is the face of the flange still flat id you put a ruler acress it?
to suit T4 single entry pattern?
Cheers,
Mick
Cheers,
Mick
hi, im not sure of the manerial.
this cost me $1200 from hi octane
I have cut about 3cm of the pipe, plenty of room to weld a new flange.
the cut needs to be grinded flat.
this was to suit a gt3540.. not sure if thats T4 or not.
  • 4 months later...
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
    • Decided for the first time ever I would tow my car TO the track day on the same working theory as bringing tools and spares "if I have it I wont need it, but if I leave it behind i will 100% need it" all setup and ready to go out and try these A050 for the first time First session showed I needed to stiffen up the dampers a touch but still managed a few 1:21's without much effort. things were looking good. Came in a dropped the tyres down  to 26/28 as they had gotten to 35/33C from 22C cold The first lap of session two I managed to drop into 1:20's. Then in the second lap into the second session. Coming into T3 and I suddenly lost brake pedal followed by some huge rear end vibrations and scraping sounds. Got it back into the pits after session ended and found this. in the attached video, all of the wobble is in the hub its self, wheel is mint, and bearing feels tight. lKXLqpd - Imgur.mp4   Deciding it was a bent spindle I tried to find bearing/hub assembly locally but was unsuccessful so it was loaded back onto the trailer i luckily brought it on to drag it back home
    • 1.05 you’ve gotta let it breath
