Hehe .. I thought this is funny! I was having a late lunch at Northbridge yesterday, when I walked past this beautiful brand new dark blue 350Z with a riced-up GT wing parking outside Gelare !! I thought to myself, this is blasphemy :whatsthat How can someone stick a really high GT wing on this car .. On closer inspection I noticed that the GT wing is the same as the one on my Supra (Top Secret GT2 carbon fibre) . Anyway, as I walked past the front of the car I noticed it had a P-PLATE AND A YELLOW STICKER. Poor kid must have had the “defect sticker” due to the GT wing. :Paranoid:
Conclusion : Black GT wing on a blue 350Z doesn't look right :)
http://www.titanmotorsports.com/topsecgt2car.html
https://www.sau.com.au/forums/topic/17719-yellow-sticker-new-350z-with-gt-wing/
  • Replies 66
haha yeah Paul and I saw the same 350Z pulled over outside of Bunbury - he was travelling with a white R33 also with a GT wing and they also pulled paul over for his GT wing - so there was 3 of us all in a row pulled over for the wings. But i assumed because of Pauls explanation of the fact they are legal that they let him go - so they mustve yellow stickered him somewhere else.
Im sorry i have to disagree with u - on the 350Z the GT wing looks horny as!! but i cant say i like them on the R33's!
Niz, don't get me wrong. I actually like the GT2 wing.. Heck, I like it A LOT. But for some reason, because of the curve nature of the 350Z, sticking a GT wing on a curved surface doesn't look right. I suppose this is why he attracted the attention from the police.
This is on my Supra, but I think the one I saw yesterday was about 50% higher than mine :) .. Beauty is indeed in the eye of the beholder :)
i saw it in the city friday arvo
metallic blue with plates '--999999' somethin like that
that gt wing looks alright suprisingly, much better than they do on r33s etc
had similar look as the top secret 350z in hpi mag...
Quote
GT wings look wrong on all cars.........
There the epitmany of RICE
Daniel
__________________________________________________
As opposed to a Yellow WRX then...
Did any one here about that Orange 350Z the Cops clocked at 242KM/h odd down the kwinana a few weeks back?
Apperently the Commodore couldn't keep up.. And it's got a bigger motor ;-D
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
