  • Replies 843
Posted Images
I was genuinely disappointed with the result - should have run another pass or 12 on the bottle huh?!?!
It wasn't running that well to be honest.... Sounded nearly as shithouse as an SR20DET.
Gate is love. :thumbsup:
I reckon 10 passes in it, maybe 1 off the bottle would have been required.
haha, ye i know the SR20 put-put sound all to well :worship:
it wasn't the nitrous at fault of course.
Go back to a stock turbo and punch 300hp worth of gas into it for the 9. :thumbsup:
Get some NUTS! :worship:
Hindsight is a precious thing.... I'd love to just bottle fhe fark out of it for a pass or two. As it stands I can't see anyone else approaching the 11.662 stock turbo mark in a hurry.
/looks_at_rev_and_winks
I'd like to see this 'stock' turbo of yours...:thumbsup:
You'll have to pull it off the car it's currently fitted to. The buyer was a bit dissapointed that it was ceramic as he knew the car and thought he was getting a bargain - HAHA!!!
Eug - I've had years to consider this build :woot:
yes should be good!! i cant wait to get my car out there again!! im afraid i will get kicked out and need tech inspection. extra 100kw at wheels and a ppg 5 speed. on a 11.3pb >_<
You reckon? :(
u could just get it tech'd u know dave :(
yep he certainly did. decided to go with the single shot for now, if i find the 125 shot isnt big enough i'll go direct port, but i'll see how i go for starters. price wise he was gooood >_<
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
