hey, people are going to think you mean me.....we must be clear that Adrian was responcible for the bodgy stuff.
Yes. Make that very clear. My car is a balance of excellent (Stu) and bodgy-as-all-fark (Me). The latter is constantly being corrected and turned into the former.
  • Replies 843
Posted Images
you go alright for a pencil pusher. you should see my brother inlaw hold a tool.
i only got nervous when you were using drills and stuff.
It has been funny as hell. I started off with spanners and progressed to ratchets (I'm only allowed the quarter drive because I snap stuff) and then I moved on to drills and other power/air tools.
You should've seen the look on Stu's face when I walked past him holding the air hacksaw!!!! HAahahahahah!!!!
Went for a drive yesterday to clean the tune up a bit so that it's driveable and not emptying the fuel tank at idle. Ended up throwing out a set of brand new plugs as the base map is so rich they fouled and wouldn't clean up no matter what we did. Put a new set in ($18 for all six :P) and with the changes to the fuel map it idled beautifully. Return to idle was a problem though and so with some more tweaks to the decel/overrun settings, it finally stopped stalling on the back-off and now returns to idle as it should.
Big thank you to my mate Kon for his help and use of his laptop and skills. I'll put some kays on it and then take it to the dyno as soon as time permits.
Also, took my rego label into the workshop to apply to the windscreen before driving it for any distance and laughed when i saw the date - October 13. $1100 to register it for a total of 6 weeks potential driving. Ouch!
Not yet, mate. Still a couple of little things to do and I've been on a big deadline with work for the last couple of weeks so no time to get them done. Hopefully in the next week or so I'll be on the dyno and then the track. Cross your fingers for me.
yeh, actaually -12 fittings, but you get the idea. pickup is welded to the bottom of the sump and piped internally to the fitting. plumbed from there through the pre filter, then pump, then inline filter then into the block where the standard filter usually goes.
so with the oil pump setup, im asuming the -10 on the front of the oil pan is conected to the oil pickup in the sump?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
