  • Replies 843
Posted Images
Adrian it is just around the corner from my place in sydney like I said if you want it let me know and i will deliver. Just get 2 seperate tunes so if it takes a while to get the next lot you will still be able to drive it just use the e85 for race days and stuie you know the offer stands mate just give me the drums and i will fill them up.
cheers Mic
Ahh the penny drops.
I will be using it (e85) in the Galant when I can get it to Yavuz for a tune again. So I will be getting it for myself it wont take much to fill up a few extra drums.
cheers Mic
Fixed. Wake up man!
lulz @ kev.
I have in the past and will in the future give Kev a bunch of credit for tuning the arse out of rotaries that go hard and run good numbers but you won't see me talking up anyone more than my man Yavuz when it comes to turbo four-bangers.
Interestingly, SDR (not SCR) had eight cars at Supernats yesterday and they were all tuned by Yavuz - proving the man knows his shit when it comes to Wankel stuff as well!!
scared........... :down:
Very scared of breaking a motor due to an irregular and unreliable supply of fuel.
Right now the car isn't tuned on the edge so there is some leeway in the tune-up but when it gets more serious amounts of boost and timing, it'll be closer to the ragged edge and I don't fancy filling it up with fuel that has sat in a half-empty tank in the ground for months because no bastard is using the stuff yet.
Fuel in drums is more consistent and that's what I need.
That said, VP are releasing Roo-85 shortly. :laugh:
That said, VP are releasing Roo-85 shortly. :thumbsup:
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
