  • Replies 843
Posted Images
Started plumbing up the surge tank, new rail, feed and return lines and other stuff today. It's not finished and the cable ties are only to hold things in place while we measured to get the right length of braid etc and won't be there when it's all done. All done with proper bulkheads in the boot and teflon braid so as to sto as much fuel smell as possible.
Big thanks to Steve from Steve's Speed Shop and BezerkR32 for their assistance.
looking good mate :P
any reason you havent used a larger return line? and did you use the very top (vertical) fitting for the surge tank feed or return to tank or return from engine?
Im asking this cause ive yet to do my setup (the tank has been mounted for months in the car though lol) and everyone does it slightly different
Hi Mate - the return from the engine is -8AN which I think will be plenty large enough. It's the top-most feed in the side of the tank. The feed to the surge tank (just below the return from the engine) and overflow from the tank back to the main fuel tank (very top fitting) is -6AN.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
