easter 2006, you over filled your trans fluid, remember when the offical pulled you and me out of the line. you had a big pool of fluid under your car in the stagging lanes and your crew guy at the time said oops, over filled the transmission.
Nah its not ringing any bells but my memory is pretty crap lately.
Adrian are you putting slick on now or sticking with the radials?
  • Replies 843
Posted Images
i looked at taking the power steering off to save weight but honeslty after driving through lee's trans fluid a couple of easters ago and getting very sideways at half track, i wouldnt have like dto try and keep it off the walls without the power steering.
just find another 20hp to compensate
No danger of losing the power steering - Stuart is just a very angry man when he gets in a weight reduction type of mood. :D
Lee, radials for Sport Compact and some little slicks for the rest of the time. Slicks aren't a priority for me at the moment though.
Does weight do that much of a difference? Should I be ripping out the original fuel tank and other little things in the hopes of getting the car lighter?
I keep trying to start a diet to lose 20kgs from the drivers seat but probably easier to get it from the car...
I'll be cheering for you to take over in SRWD to give shane a run for his money... :(
I'll be cheering for you to take over in SRWD to give shane a run for his money... :D
Weight makes a massive difference but remember that in some classes, as with SRWD, we have minimum weights to meet. Shane and I don't have that problem because we drive tanks that only have to go 3250lbs (3100 + 150 penalty for non-OEM box) which they seem to do easy enough.
I'll just be happy to be back out there racing again and hopefully a little closer to the pointy end of the qualifying order than my normal 4th - 8th position.
the weight penalty for the trans is only in the ANDRA book, not in rays. when they merge next year there will be no weight penalty for the trans. that comes from both the box and sharpies mouth. :D
Well you just made my f**kin' day! 3120lbs here I come! Stuie, get the spanners out! :(
I'll be cheering for you to take over in SRWD to give shane a run for his money... :banana:
aly fuel tanks ftw :bunny:
Dont worry, allready had the hole saw out. your going to have to put weight back in by the time im finished... :banana:
Well you just made my f**kin' day! 3120lbs here I come! Stuie, get the spanners out! :bunny:
Stu is just sticking to his name.........doesn't want to lose the Bezerkly identity.
He's also making you a nice free flowing exhaust for the big arse turbo - he's taking a screwdriver to it!
That's okay. I don't delude myself that it's much of a street car any more. Sure it's registered but it doesn't see the street very much. The exhaust can be as screw-drivered as Stu wants :bunny:
I heard from a liitle birdie that yhe machine work will be started on your engine this week.
How terrible do nitrided crankshafts look? Like it's been sprayed with pressure pack primer....poorly!
Looks pretty big....what is it 8L?
You could give me the whole engine....that would save you 200kgs at least >_< I mean only if you really wanna save some weight. :P
8.5L. 200kg you reckon? It'd be fairly quick then!!
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
