  • Replies 433
Posted Images
got the lines fitted last week i can acctually say there is quite a big difference in brake peddal feel
no more spongy fill to it nice and solid cheers mark very happy thanks mate.
Cheers
Allan.M
What are the brake pads like pad vs rotor wear?
The high performance pads (500 degree) are equivelent performance-wise to Bendix Ultimates, but should last roughly twice as long. The high performance pads also produce about 90% less dust then the Bendix Ultimates.
The track day pads (750 degree) can handle approximately 100 more degrees than the EBC greens. They will also last roughly twice as long as the EBC greens and have about half the wear and dust.
Obviously all these figures depend on your driving style, but these are a rough estimate.
If anyone has anymore questions, please ask.
Cheers
Mark
Braided brake Lines --- is the group buy still going?
When is the last day?
Also how long does it take for delivery?
I have track day end of nov (this month) .. so i would need it soon
Also is this a bolt on type job?
Anything else required to fit ?
cheers mate
Edited by siddr20
cheers mate
Hi siddr20,
I'm taking orders for this GB as we speak. GB closes at the end of this month.
Hoses are generally being shipped the day after payment is received.
These are a direct replacement for your old hoses, so just take off the old ones and put the new ones straight on.
All you'll need to do is bleed the brakes slightly once you put the new hoses on. Fairly easy to do.
If you have anymore questions, just ask.
Cheers
Mark
Hi Mark,
i see now you have the Stagea fronts for the braided brake lines. Are they the same as the R33Gtr? how about the rears? Is the stagea for a RS4s or 260rs? Will they be the same? Let me know.
Do you have anything for the the pads? Its equilvalent to the R33GTR brembos.
Hi Mark,
Hi stasis,
From memory, from what BrakeWest said, the hoses are similar to the 33 GTR. The rear hoses are a pain in the a$$, that's why BW aren't doing them. It involved changing changing some fittings on your car from imperial to metric and was more trouble then its worth. This was all for a 260RS, not sure about the RS4.
For pads, BW don't have anything available for Brembo systems unfortunately. I was using the K750's with my standard GTR brakes, but since i put Brembo's on the car, I've had to settle for EBC's.
Cheers
Mark
Hi stasis,
Cheers
Mark
ok thanks
Hi stasis,
Cheers
Mark
ok thanks
Hi stasis,
Cheers
Mark
ok thanks
Hi stasis,
Cheers
Mark
ok thanks
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
