Hey s13drifter,
Yeap, my car has a completely stock motor, including stock turbos, injectors, fuel pump, intercooler etc.
I bought my car in September last year and drive it very hard. I go cruising once a week with a club that I am involved in and have atleast 2 or 3 runs on these nights......all of which involve 6000rpm dumps and then 8500rpm gear shifts.
The extra reving helps as you will then enter the next gear in the middle of it's power band. Even though over about 7850rpm my car starts to loose power, the torque of the GTR will keep it pulling to a certain extent.
I have recently upped the power on my car with a few mods and ran an 11.57 at Heathcote on Sunday.
The motor pulled 240rwkw on a the dyno that all the guys in Vic just had their cars done on and the motor is still very strong and compression is still up.
I am running 1.2 bar all day, everyday and do a good 500k's a week.
The GTR is a very strong car and can take a real beating. I am out to prove this!!
Shaun.
Originally posted by slip
There is ONLY ONE import owner with a manual who doesn't worry me, and he's rarely on here.  You lot are mad!  Revving to 4000rpm all the time during normal driving!  THEN you complain about fuel consumption... :lol: whyyyyyy.  I think its because you are all so isolated and insulated from whats going on.
Unless gearing or conditions dictate otherwise, i shift at around  2000rpm now.  Hot or cold.  I used to go up to 3000rpm sometimes if i was in a bit of a hurry, to punch up a hill or something, but now im really povo (fuel), and plus, if im not going hard, its not fun anyway, just gonna wear the engine more.
funny thing is, the one import driver i mentioned has a modified Vspec.  Cuts sick on track days though.
This is a pet peeve of mine, if you hadn't guessed.
P.S. Used to own a 20,000rpm roadbike, at 6000rpm it was still doughy as poop. :cool:
hehe slip...it's YOU who I was talking about in my first post...i remembered you asking me about that, so i wanted to see what everyone else did :)
Just as matter of interest most of you are indicating that when cold you rev to a certain rpm only to protect the engine etc. What indicating factor are you using to determine when the engine is warm if you don't have a oil temp guage?
Hirisk,
that is excellent rwkw on stock setup other than i assume exhaust and 1.2 bar boost and a rev limiter removed. That's an awesome 1/4 mile (you must have changed the clutch to get that time?). Just a recommendation when doing your 6000rpm dumps try and have more than half a tank of fuel because the tank setup on the R32GTR can starve your pump of fuel on launching. If you could do a injector duty cycle reading u would find that it would be at max however the standard ecu will just retard timing to protect but you don't want to starve the fuel pump as there is no protection barrier there.
When cold i rev to 3500rpm
cruising 5000rpm
giving it... well limiter is set at 9000rpm and its a treat to use it
Cheers
when the engine's cold: i dont drive... i sit there & wait for it to warm up. even if im running late for something... it can wait. :cool:
when the engine's up to temperature: shift point for normal driving amongst the Excels & Commondoors is about 5500-6500
when im giving it some schtick: 9000 :)
I'm with most of you guys..
IN the mornings when cold, i try to keep it of boost and under 3,000 till its warm, then normal driving i keep changes between 3,000 and 4,000...
I dont like revving it to hard in first for some reason when i give it a bit...Probably only take it to 6,000 - 6,500, then take it to 7,000 in second n third, and as much out fo fourth (dam governors!!)
Scott
Hey INASNT,
Nope, my factory computer has just had the Rev and Speed limit removed. It has a "Yellow Hat" sticker on it which is a Jap parts company. It may have been remapped by them, I am not sure. But even if it has been remapped, it still runs at very similar mixtures than most stock GTR's that I have seen on the dyno. I am sure that it is just the Rev and Speed limit that is removed.
I don't have a fuel pressure reg either, all stock items. My injectors are right on their limit though and I am sure the turbos would be too.
Hey STUGTR,
Yeah, I have a Exeddy Diken Three Puck Single plate with heavy duty pressure plate. Awesome clutch.....has not let me down yet!!
You can see my mods here......
http://forums.skylinesaustralia.com/showth...=&threadid=1335
Thanks,
Shaun.
thanks for the info HIRISK i thought i was givin my motor a hidin goin to 8000rpm. What do you plan to do next to your car?? Mine has a single t51 but with a different front compressor housing slightly larger than the old t51 housing which mine is. I must say im not the biggest fan of it mainly due to the lag and the fact i can only run it at about 16psi when it should really be running bout 30psi but my stock internalls i dont think they have it in them for 30psi thats why i believe it is so laggy. Whats the price on that clutch mine is a single plate but is really modified i dont like it much as it is way too heavy heavier in fact than a friend who has a tripple plate:uh-huh:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
