Hey everyone.
Currently got custom made adjustable K-Mac sway bar on the rear of my R33. It is much thicker than stock item and i could feel the difference in terms of the rear being a little more stiffer.
I bought this item 2nd hand from a friend so i got it at a really good price.
This is a little more expensive than whiteline.
So i was thinking of purchasing some thicker ones from the front- either whiteline or cusco
But i wanted to know if its safe to have mis-matched sway bars?
The reason i ask is because each sway bar is a little different in terms of adjustment!!
Also whats the best setting i should have the sway bars for normal street driving?? All at lowest settings? that is not so stiff??
Cheers for the help
Sidd.
ps heres a pic of the sway bar:
Edited by siddr20
https://www.sau.com.au/forums/topic/177763-mis-matched-aftermarket-sway-bars/
Dam it Sidd ! Your the one who beat me to that rear sway bar ! Ha HA !
Seriously though ! Shouldnt be a problem really as the majority of your body roll is controlled from the front so just get a heavy duty adjustable front one the same diameter as the rear.
As to settings thats really personel choice. But I sugest you start at the lowest settings front and back, drive around for a while to get used to it then got up to the next setting and see how it feels.
Hope this helps Dude
Having a stiffer front swaybar will just induce more understeer, so if it applies "too strong" an effect its not as dangerous as running an overly stiff rear bar....unless oversteer is your thing :D
If the price is right, go for it I say. If worst comes to worst you can either sell it, or sell your K-Mac and get the matching rear bar from the same manufacturer.
Since its the front bar, I'd suggest running it as stiff as possible (that way its going to be as understeery as possible, and as any OEM will tell you understeer is safesteer), see if you like it, and then slowly make it softer and softer until you find the optimal balance. Vice versa on the rear bar, if you're trying to adjust relative balances.
... and as any OEM will tell you understeer is safesteer ...
understeer is "idiot" steer. The reason manufacturers build in understeer is that the solution/reaction to understeer is to stomp the brakes - the natural reaction of the less-than-average Joe Citizen driver.
nice bar.
have a look at some of the whiteline kit that are on offer.there are different combos that can be purchased in regards to front and rear swaybars.adj or fixed-22mm-27mm thick solid.i think they may even go thicker.not sure though.
is that bar you have a solid and not hollow?
mine is 24mm front adj and 22mm rear adj.if i remember correctly.they have made a big difference to the way that the car handles.and having adjustabilty there makes that much more difference when you are looking at getting different reactions from the cars handelling performance.also adding camber to the front helps allot for handelling.but wears the tyres out unevenly.
PLYNX- hehe it was up for sale for ages.. no one bought it.. so im like might as well..
Cheers for the replies.. I might just go into K-Mac shop and get their opinions. They only about 20-25mins away
So for a bit of balance for normal street driving, you saying have the front a little bit more stiffer than the rear?
Atm, the rear is at lowest settings..
Edit: I think its a solid bar. Will double check tomorrow.. Does it make a difference tho?
Edited by siddr20
Basically, yes. Swaybars improve response, at the expense of grip. The stiffer you make one end of the car, the more that end wants to push. Stiffen the front, better steering response but more understeer. Stiffen the rear, the back will want to come around faster but you'll find power-down isn't as good as it used to be. Stiffen everything up, four wheel drift time. :thumbsup:
When I put adjustable swaybars in my car with stock suspension, I ran them at full stiff and it was great. When I installed my coilovers (where the spring rates are 2.5x stock), a light touch of the throttle would have me simulating Tsuchiya (actually, more like Lucas Black in the S15). Now I run the fronts full stiff and the rears full soft, although I may peg the front swaybar down a notch and see if my steering is still as responsive while making the car a little more neutral.
Thanks for the help!! Helped a lot..
Being RRP of nearly 400 for this custom made bar, i hope its solid.. Was heavier than the stock item when i put it on.
But didnt really check.. Will do it tonight when i get back from work..
Cheers all
Just to add my 2c and muddy the water a bit.
Yes, you can run bars made by different manufacturers, however, you may find that their range of adjustment is insufficent for you to make them work properly together. You may end up with a car that, once you reach the limit of adjustment (eg front full soft, rear full hard), is still understeering, and so you have no option than to find a bigger rear bar or smaller front bar.
I found whitelines 24/22 combo on my r32 terrible as there was insufficient adjustment to get the car neutral. I had to upsize the rear to a 24mm bar to dial out the understeer completely.
I disagree with scathing a little on the understeer point, i tend to think it's a bit pointless getting bars if you aren't trying to get the balance spot on, tending to a touch of understeer at the limit (atleast initially).
Sorry being lazy to check if its solid or hollow. Will do it today!!
BhDave- Yes you do have a point there. I did think of that before!! I might just go into K-Mac and get another quote, and ask their opinion and see what to do..
will keep you all informed..
cheers
on a lil side note, if your paying $400 rrp then your gettin ripped off, id rather buy an off the shelf cusco one if your gona spend that much, or a whiteline one which would be half the price thereabouts. my 2cents
Nah i didnt pay anywhere near that RRP price.
Just remember that price is from a shop. So they also have overheads etc..
Also remember most sponsers on here probably just buy direct from the brand.. cheaper prices etc..
but lets not get into prices.
Another reason why it cost more is because this sway bar is SOLID, fully adjustable.. made here i think.. anyways.. lets not debate about that..
Whatever you use, DON'T set up a car to understeer. It FEELS safer than oversteer, so I s'pose you feel a lot calmer an instant before you hit the tree.
Work it out yourself. If you're going right, and the understeer is preventing you, and you put on more lock ( and put front wheels more sideways ) you lose more traction on them, and it understeers MORE, etc, Here comes the tree!!!. Oversteer is the opposite. You're instindtive reaction is the right one (work out what's happening with the front wheels) It might feel a bit tail-happy, even if you over correct. Your gut reaction STILL tells you which way to steer. All you need to know is where you'd like it to go, and keep repointing it there, and you're always doing the right thing. Most FWD cars are natural understeerers. KEEP OUT OF THEM.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
