  • Replies 175
hey R DIRTY 3 just letting you know i sent you a PM as i cant find it in my sent folder
Yup i got it and have replied.
Gazza, yeah mate CAMS will recognise them. I have it in my car and never been questioned about it. And i asked Revolution Racegear and he said that its the minimum they accept at Wanneroo etc.
Where is a good place to put it?
While on the street I was going to bolt it into the boot somewhere..
While on the track which I wanna give a go.. maybe just infront of the passenger seat on the carpet as close to reach for driver as possible?
Any other ideas?
Any other ideas?
Front Passenger floor is normally a good spot for it. I know a guy that is going to try to make a bracket to mount where the seat bolts on so i dont have to drill holes in the floor...also consider mounting it to the tunnel behind the centre console?
Are you allowed to remove your passenger seat while doing track in a street car? If so that'd be sweet bolting to to the rails.. I don't think it needs to be in the cabin while normally driving on the street.. I wouldnt trust silly drunk passengers :)
yes you can take out your seat or you can just get a piece of metal that extrends from each bolt that holds the fron of the passanger side seat in, you then attach the bracket that the fire extiguisher comes with to that :)
only problem in a 33 is that the seat has to be adjusted all the way back to make it fit :)
id post pics but im at work
p.s. brad, i want one now lol i wanna replace my supercheap auto one :)
Can I offer some (maybe worthless) advice?
Make a bracket to bolt the extinguisher to the front of the drivers side. If you bolt it to the passengers seat you will always have problems with clueless chumps smashing the seat into it when the move it back/forward etc. If it is infront of you then you know it is there & you won't damage it or the seat.
Secondly scrutineers much prefer it if you can reach the extinguisher from where you are sitting.
$50 to you! :)
Agreed :)
Guys so far we have the order looking like this:
Strich9 x2
342Four x3
Go 33 x1
Bubba x2
Lukits01 x1
Daniel R32 x2
RDirty3 x1
7yphon x1
Ossie 21 x1
Fr0st x1
PX29 x1
Hazerb30 x1
Woodys x1
MIKE R32 GTR x2
Onthehunt x1
Bok boK GuN x3??? To confirm
Ztuned x1
3R1K x1
DiNoBoNeS x1
Sky Ryan x1
Gazza750 x1
R32SkyRine x1
Kuju x1
Lach 32 x1
Sam5709 x1 (special price $50)
WhiteHot R33 x1
pism x1
Munster x2
Gabbo2047
TOTAL 38
If anyone wants to add to their order or cancel or change it in anyway now would be the time to let me know. I appreciate the support from you all on this.
Ill be sending PM over the weekend to everyone on this list advising of payment methods. I wont be ordering until Thursday 2nd August so it would be really good if we can have all payments sorted by then to confirm the order, as they wont be dispatched from the east until payment is made.
Thank you all
Brad
p.s. Bok boK GuN, have you had confirmation yet?
ill have one please , btw is there any problem with boltign it on passenger side of center console , will i get introuble with the men in blue ?
o i livein rockingham and ill pay for postage if u dont mind sending mine if im notto late
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
