Hey Guys,
I recently purchased a Greddy Type S bov, which is in fairly new condition. I'm just having problems with getting it to work on my Ford xr6 Turbo.
So i was seeing if theres any skyline people that have fitted one of these and live in melbourne.
Mine just flutters loudly for about 3 seconds when im driving and hear a slight high pitch *ting noise that is extremely quiet.
anyways, was hoping to see if there were any guys that can help me out, as guys on the ford forums obviously can't since those guys arent familiar with these products and they all stick to their turbo smart bovs.
Thanks
https://www.sau.com.au/forums/topic/177796-greddy-type-s-bov/
I would look at the adjuster on top and wind it all the way in... maybe even upgrade the spring inside.
Your trying to vent a very large amount of air through the budget range trust bov designed for a much smaller engines.... you should be using the type r.
oo i see. hrm
my cars actually stock, and i've tried it on a heavily boosted xr6T and it sounded and reacted the same.
- I opened this bov y'day and it actually has 2 thing springs of the same length. one just sitting in the middle of the other one.
i have fiddled witht the aduster.
having it full in. and then to really soft
haivng the screw at mid-point. i can get it to go pssh but then it just has a long high pitch whistle thats really faint.
Im wanting to try and connect that smaller nipple to a hose as well which i read, makes the bov function quicker and louder. Do i have to make my own connection for it on my car? as my car only has one main vacuum hose.
the second nipple is usually used to control boost, similar to a wastegate but on the pressure side, i have used it to good effect on smaller cube engines... i doubt it could pass enough air effectively on a 4litre.
ok. np .
Thanks for the advice.
i forgot to post my pictures up before hand.. here they are.
its not the best setup as its using the wrx adaptor. and being an ebay item, i did want to see if it actually worked before buying the correct adaptor which i'm ordering off ebay now.
I am still concerned as i put it on my mates '98 wrx and i didnt really hear that high pitch whistle at all as well.
anyways, ill see what happens when i hook it up to the appropriate adaptor. cheers
but the plumback attachment isn't connected to anything? So while you might not hear the loudsest *insert noise here* you should hear something. People with skylines have gotten something similar simply by disconnecting the plumback hose and blocking it off.
I have no idea how the WRX's are set up, but the way that is, would it be very responsive? If at all? Becuase you'd think that tiny little pipe that the BOV is connected to might even be a little restrictive?? I'm merely guessing here by the way. Andrew, if you've seen the setup on skylines you'll notice that the BOV's are directly attached to the intake pipes, not off a small seperate hose, don't know if that means anything or not.....
yep i understand the bov's are attatched off the intercooler pipes. I just wanted to actually see if this BOV was in working condition after buying off ebay. but this adaptor directely clamps into the i/c hosing.
I've actually found an adaptor on ebay after a long search. which will require me to cut up my rubber i/c hose and clamp this in. so i shall see what happens then.
hey mad082, all the clips i've seen off youtube that have people reving their engines and their greddy type s make the whistle, they don't actually have those trumpets? but i wouldn't mind putting one on it.
looks like i gotta do some more ebaying now.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
