Hey all heres my probs, im kinda thinking the engines gonna need to come apart anyway, but its driving nuts what all this could be.
When i take off, i get a puff of blue out the back. Then if i slightly boost it (bout 5psi or more), more blue shit. But it will only do this sometimes, say i drive to work, it'll do it. Then when i drive home, no blue at any time at all.
Then sometimes when i crank the car over to start, i can hear it doesnt sound right, low comp on one cylinder, anyone can clearly hear it. But only sometimes when i crank it.
When i exit the car with the timer going, i can hear it missing out the exhaust. but only sometimes.
Did comp tests, came up with an even 155 give or take a couple. Engine HOT but this is when the cranking sounds fine and no miss. The engine has done 8,500 ks, forged acl pistons n rings. Valves were reground and new nissan stem seals used. Hi-flowed turbos done with the engine.
No oil in the cooler piping or breather pipes, running 18 with tuned PFC. How can these problems possibly be intermittent? and ive been watching out the back while im driving lately like a hawk to see. I havent changed anything at all, this has all started suddenly.
Soz for the novel, any insight would be good.
Cheers,
Mat.
*sighs*
Sounds like my car, except mine does it all the time :D Rebuild time for me haha
I had low compression on cylinder 6 which eventually got worse till its 0 comp now
Edited by Yawn
Blue smoke usually means that oil is coming out the exhaust.
If it only does it when the engines cold remember that hot metal expands so the oil is probably not getting thru a gap that is present only when the engine is cold.
I hope for ur sake its a turbo on the way out and not a busted ring.
Well, when the blue smoke happens, the car is at NOT, when driving, i always let the car warm before i drive it anyway, ive done that all its life. I never drive unless its at about 40deg.
Haha ive got a feeling it is something serious...
i would suspect your turbos for the blue smoke.
Yes head was fully reco'd; revalve regrind reset clearances etc etc, genuine nissan stem seals used...i guess that still doesnt eliminate them though.
Could very well be a turbo or two, would a faulty turbo leak oil only sometimes though? Once again theres no excessive oil in the IC piping or breather system.
A vacuum leak or dirty afm wont cause low comp on cranking, what would, but only sometimes?
how do you know the low compression on cranking?? have you tested this? i have never heard low compression on seen the results. the other thing is a dirty crack case breather but i would have thought this would be a all the time thing
Its easy to hear. Kinda hard to explain...if you pulled one spark plug out then cranked the engine thats what it sounds like.
Im leaning toward valve stems and seals.
After much discussion i think a problem has been caused by the head porting. The lower part of the valve guide was removed during the porting, and i think this has caused valve stem and seal wear, this could explain the intermittent low comp issue if the valve is worn from side to side, it would only seal sometimes?
Is that a worthy point?
Low comp when cranking needs to be proven. DOnt assume it is. A lazy battery can cause they symptoms of low compresion when cranking.
But it doesnt do it all the time...straight after it was doing it, i tried to catch it and did a comp test quick, but everything was ok, and it suddenly decided to crank fine.
I had a missfiring issue at idle and low load, low revs. Thought I'd lost a cylinder.
Checked compression,plugs for oil etc, all ok.
Cos it has cams, it's a little more missleading.
Wiggled the injector plug and miss went away. Fixed that up and shes all good.
Little things, always the little things.
I'd go with the turbo seals for that one, followed by valve stem seal.
I agree...just ask TO4GTR about his "miss". Changed engine and miss was still there. Ended up being a blocked injector. :thumbsup:
I have a similar problem with my engine/turbos....blue smoke on overrun. Check turbo seals and then stem seals. Both are better than a piston ring issue.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
