Item: set 4 semi slick bridgestone re55's 225/50/16 that are on r32 gtst rims
Website: this and advertised elsewhere
Item Condition: good
Reason for Selling: have no use for them. came with a car
Price and Payment Conditions: $1000 ONO
Extra Info: Have approx 70% tread left on them.
Pictures:
Contact Details: PM me
https://www.sau.com.au/forums/topic/178756-semi-slick-track-tyres/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
