http://www.rezlo.com/Pages/Toys/Silvia/Kil...%20in%20S14.wmv
Little while ago against a S13 running 1.1bar with a GT28RS,
I run a GT30/40 on a stock internaled RB25det sqeezed into an S14, run was done at .85bar, ran an 11.92 the next day.
Set up is now running 1.45bar with meth injection, launch control ectr still on the stock engine. Hope to do an 11.5 before I do the rebuild in Dec
Well since where posting up skyline videos lol..
This R34 has a nice spool and the maddest dose I have ever heard from a R34, built and tuned by HKS..
http://uk.youtube.com/watch?v=t0XjPnsCbA4
This 2nd R34 is built by MINES, and is an absolute machine. Crazy spool up.
http://uk.youtube.com/watch?v=42KwIMakoaE
Enjoy!
Thanks,
Abu
Those 2 clips were crazy, i loved the white r34 in the second clip that thing sounded mental :P
I tought this was for YOUR spool? Anyways heres mine, cant really hear it as the damn screamer drowns it out. Please excuse the two stooges (a mate and younger brother) talking at the end they mean you no harm lol
:) DAMMIT! stupid work computers wont let me go on youtube now either, ill try fix 2morrow. but post up your stuff boys, cmon
Yeah thats why I said I was breaking from the habit - hardly anyone has actually posted their own cars. I could have posted some awesome ones of other peoples.... but anyone can find a random clip on you tube.
yeah i lik hearing other peoples, its more interesting than sseeing some clip you have seen a million times.
if you want to find mine, search youtube for hks 3037 and its under "my screamer", ill post the link next chance i get when im not at work
Never mind... :)
spam much?
DjeMz with the muzzatek 3000 flutter, niiiiiiiiice (4 inch intake on mine makes my flutter sound like crap, but i dont care, only reason it flutters is i CBF plumbing in a bov)
Edited by ardie
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
