  • Replies 183
nah man don't CA18 it, they are alright engines, but sound like diesel tractors when modded
20 or 25t it :mellow: do it :) come on, make us proud
Glad to see you didn't go anywhere near an MX5....
The GTiR would've been cool, but no RWD switch(they are front biased :()
SR20DET requires too much fabrication same with RB2XDET - also needs new GB for SR or RB
the CA18DET bolts straight in to std engine mounts and Gearbox. And they are cheap.
If this one on e-bay goes for $600 ish then an 2nd hand ECU for I dunno $500 ish
Lock the diff and viola turbo dorifto for $2.5K
Pick it up tomorrow :(
ca18? you can almost get an rb20 for that price ;)
edit: oops, didn't read your post
Yeah - but this is different - it's a Nissan :worship:
And this one has rego and is not a ex rally car like the laser was (impossible to get registered)
One drifter coming up :teehee:
Ha ha
YES, I am a glutton for punishment - but I love it.
Even though the laser project failed, I had fun with it !
Hmmm - there's a CA18DET on e-bay for $400 - 69,000 kms....... NO NO NO Don't do it !
Edited by MANWHORE
I'd farken love to put a FJDET in it - but there are as scarce as chickens lips - and when you find one - expensive.
CA18DET you can get an engine, loom and ECU for under $1K
Other options are of course SR20DET - would need gearbox as well -
RB25DET would be good Maj - but tricky install with new mounts and so forth.
It's GREAT FUN to be in a manual again - I forgot how much fun they are :/ I love revving the crap out of the CA20E.
Adam - the plans of grandeur for the Laser never worked out - it was just going to be too hard and not worth the $$ - so sold it for $2K with some new bits (bought it for 1K)
Issues so far:
LSD - you can't get one unless I convert the live rear end to IRS - which involves cutting off the whole rear cradle and welding a new one in.
Thought hard and long about locking the diff - but since it will be a daily - not really worth it, I don't think.
In terms of engine upgrade - I'm finding it hard to justify spending $$ on it since it was cheap - but I guess I will at some stage.
Brakes - to get 4 pots on the front - I need to swap to S13 front suspension - Axle stubs, Knuckles, LCA, Tension Rods etc. Would also need an SR master cylinder
Rear drum to disc conversion - simple matter of swapping for a B'Bird TRx S3 disc hubs etc - IF I COULD FIND THESE.
The body is fairly straight and rust free - so that is a bonus - it's a bit tatty - but in overall good condition for it's age.
My problem is that I am too damn impatient and want it to be a hella circuit drifta over the weekend - but in reality it's gonna take a while to source all the parts and do all the work.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
