Legal i think is 1" up and 1" wider.
So stock is 16.6.5"
Legal Max would be 17x7.5"
Feel free to correct me if im wrong.
haha puts me in a bit of trouble. i thought it was 2" and 2"? anyone know for sure? i have been pulled over and cops said to me that I got pretty wide tyres on there but did not say about them being illegal.
I believe the 1" out is referring to "track", you cannot change the TRACK of your vehicle more than 25mm either side. That said, if you want to go 2" wider you would need to get the correct offset so the TRACK doesn't change by more than 1" and hope you can clear it on the inside :D
i think that you'll find that bubba is right
that, and the tyres cant actually protrude past the base print of the vehicle
so all my mates with those big muddies on their 4bees are actually illegal...
it used to be up to 7.5" in width, unless larger was a factory option.
and 2" increase in diameter as long as the rolling diameter didnt change.
now it is 1.3x the largest factory optioned rim width, providing the track doesnt increase by more than 25mm, and that it doesnt foul any part of the car.
and diameter can be anything that will allow for the same size rolling diameter.
also staggered sizes is still a big no-no, unless it came standard, but none of us drive porsches, so it doesnt matter!
ps. DPI is your friend, if in doubt ask them, rather than get 4574987504579437543750435 answers off the forums. :huh:
It is on a percentage ruling now from VSB 14 - National Code of Practice for Light Vehicle Construction and Modification (NCOP) with the link to DPI below, with V35's and 19's being an option you can go so big now and stay legal.
http://www.dpi.wa.gov.au/licensing/1421.asp
http://www.dotars.gov.au/roads/safety/bulletin/vsb_ncop.aspx
ps. DPI is your friend, if in doubt ask them, rather than get 4574987504579437543750435 answers off the forums. :)
I like the sound of that :whistling:
My Chaser has staggered sizes standard, as does Supras etc, so I can have (according to 1.3x) up to 9.5 wide, which is nice, since I have 9.5"s on the rear, had wondered on the legalitys of it :)
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
