  • Replies 287
Well, I can provide a camera man with digi SLR and access to areas at the National Museum you cant normally get to (should be able to, work for the security company and the camera man is security at the musem), plus i might be able to talk the guys at the war memorial (also same security company) into letting us do it there. We do questacon too, so since my car probly wont actually be in them, let me know if ya wanna use any of these sites and ill see what I can do.
Check some of his stuff out on his myspace, hes pretty good.
http://www.myspace.com/jm_jmedia
Edited by datto260Z
Hey thanks... this sounds great! Find out what you can and let us know if its okay to go ahead - the museum shots looked fantastic.
We need to start thinking about when, if we need extra lighting etc then a weekend may be better to give us time, but this may not suit the Museum, War Memorial, cameraman etc so lets start with them and try to work around that.
Which car?
Anyways, there is always guards at these sites and Justin said hes more than happy to do the shoot and to help me try and get you guys a good spot at the museum or where ever.
I know everyone and their dog has done a photo shoot at the tunnel near Questacon, but a group photo would actually look pretty good, but thats all up to you guys.
I kinda need to know which site you want to use straight up, so i can organise in advance, it wont be easy and I may have to do "favours" :(
Edited by datto260Z
I kinda need to know which site you want to use straight up, so i can organise in advance, it wont be easy and I may have to do "favours" :mellow:
Lets vote on our first site (it won't be our last).
1) National Museum
2) Tunnel near Questacon (is this called Reconciliation Place?)
3) Under Commonwealth Ave bridge
4) Top Westfield Woden carpark with Sky Plaza in background
5) War Memorial
6) Other
I can offer to help out with some of those favours you may have to deliver on... umm would knee guards help you? :(
Edited by LadyBytes
We may choose two sites, one which involves other people such as Museum etc and one we can do without needing to involve others too deeply... such as a carpark or lake edge that we can do at leisure if we feel we need more when the first shoot is over.
Joel's green supra. He painted the car himself. Former member of MR2 club, current member of CCG...
Yeh, he lives in Sydney now, but he comes down to visit everyone ocassionally.
Justin says thanks for all the comments of his photos.
Yeh, those "ataboy knee pads may "come in hand"" later :cheers:
Sorry, that was bad :P
I don't really mind where its held. Just would like to participate.
Agreed :thumbsup:
Like the lake at nighttime though, maybe Mt Ainslie with photo taken down from high up on the viewing point facing down towards cars with city lights in background if possible.
You mean like this? :thumbsup:
overexposure ftw
Edited by Bluprint
dam, here i was thinking i had an original idea haha. Looks good though, maybe it should be during/after a meet up at the museum on a friday, head to the museum early, group together and cruise up the mountain for a photo shoot.
Agreed, lets do this as part of the Friday cruise - Whats this Friday like?
hmm might be too early notice for me :X
Will get back to you when i get home from work tonight whether i can make it or not
If you can't make it, we will hold off until you can :D
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
