very good, seems like its all thumbs, besides some people that are fussy. keeping in mind its for a 33 so all who have commented with a 33 your help has been good thanks! thanks for your pics to DMR.
cheers mick
yeah dude go for it....i fitted one last weekend.......
few things to note.
*search for the instructions to fit a hybrid cooler. it has pretty much the exact location to cut the hole...i cut mine a cm or two further back so i wouldn't have to trim the fan.
* there is no nipple on the piping for the boost control.....i just tapped a thread in the piping and used some loctite...to seal it in there
* headlights were a bit of a shjt to get back in....had to modify a little bit.
* Angle grinder and jig saw are your best friends doing this job
Good luck man....if you need any advice throw me a pm as its still pretty fresh in my mind.
Mick
  • 2 months later...
I fitted one today actually!! Felt a huge difference.. Seems like turbo spools up a lot quicker :)
Haha... I felt no difference after putting on 34 SMIC. Didn't really feel a difference when I installed 3" turbo back either! Maybe I just need a tune.
What engine management you running now Sid?
you get what you pay for...... :D
thats true to a point but then if thats the case and a ferrari spyder is our benchmark (as would say a hks intercooler kit) then i guess what you are trying to say is we all drive peices of shit!
i dont htink so...its all about application and practicality. you wouldnt put a diamond incrusted turbo on your car would you now...'but it cost more so it must be better!' un no thats not the case.
anyway, for most people.. you will find the just jap intercooler kit more than adaquate!
ive fitted them to a few cars before, you do get what you pay for to a certain extent as far as the finish goes, some of the pipworks needs a bit of stuffing around to get the where its suppose to be which you wouldnt get that with a hks, arc etc kit but for the money you pay for them they are pretty good for a everyday street car with a bit of extra power, so as long as your not looking at huge amounts of power you really cant go wrong with them, so long as you dont mind some things ill fitting, just work around it :D
anybody felt their car NOT going so well after puttin 1 of these kits on?? friend of mine recently put 1 on his 33 4 door, and he swears 1st/2nd gear do not pull as good as before, but 3rd/4th gear go like all hell! Had it dyno'd to check the afr's and its running well rich, and only made 165rwkw on 11psi! changed the plugs to bcpres 7's (i think it was, 7 heat range thats for sure) but it still does not go that well in 1st/2nd. Any ideas? He's has read somewhere that a SAFC might help a fair bit?
Sounds like your friend did not install it properly, or he has other issues which are causing the performance problems with his car.
he'd do alot better with engine management and a tune. safc should do the job
i just installed my JJR type 1 kit on my r33 in the last few days. bit of chopping here and there and abit of stress but it all worked out fine. took it for a run last night and i felt an improvement straight away. feels more torquey down low. definately a good buy. took a day and a half to fit it all up by myself
to the dude that fitted a r34 smic and didnt feel much improvement, did you clean it out first? im not trying to stir, just curious.
Yes I first filled it with turps several times and shook it around, left it sitting awhile, then used metho to get rid of any residue.
Honestly I didn't expect any improvement and don't see why it would improve (well not noticeably anyhow). Except if you are boosting it for long enough that the stockie gets heat soak which I don't really do... The reason I got it was to be on the safe side.
Edited by bombastic
I had a just jap 100mm tube and fin cooler for my R32 GTR and i pulled 335rwkw with it on. It is ok but doesnt seem to like the repeated dyno runs when she has been pushed.
It seems good to get to this power but i am changing to a Trust cooler only because i am changing turbos which will get me to 400R+rwkw ,and we felt this cooler was not flowing enough to go beyond this point, but hey for 300 odd dollars to get to this power is still great mind you i still have the standard rubber piping i just replaced the cooler only.
Also any one interested in a 2month old jjr tube and fin cooler i will be selling it cheap $250 still like brand new i live in Sydney.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
