FOR SALE
GReddy Front mount Intercooler with Piping to suit RB25 - Hardly used, Perfect condition less than 1000k's through it. $600
GReddy Electronic Gauges x 3 - Oil Pressure - Exhuast Temp - Oil Temp - No sender units. FREE Gauge holder to suit EVO 6 $250 will not seperate
RB26 Coil Packs Standard - 70k's on them. Should fit RB25 as well? SOLD
3inch (75mm) Front pipe for RB25 - made by Exhaust Technology. To bolt up to low mount turbo. exhuast sensor included $180
R33 Front rotors 296mm x 2 - 30mm thickness $50
R32 GTR Braided brake lines -front and rears - Less than 1000k's track use - straight swap from standard $240
SPOOL Adjustable Cam Gears to suit RB20 RB25 RB26 - Anodised blue $150 Pair!
Can post at owners expense!
Grab your self a bargain and help me clean out my garage!!
post-29370-1186737839_thumb.jpgpost-29370-1186737861_thumb.jpgpost-29370-1186737875_thumb.jpgpost-29370-1186737893_thumb.jpgpost-29370-1186737910_thumb.jpgpost-29370-1186737924_thumb.jpgpost-29370-1186737938_thumb.jpgpost-29370-1186737953_thumb.jpgpost-29370-1186737970_thumb.jpgpost-29370-1186737988_thumb.jpgpost-29370-1186738002_thumb.jpgpost-29370-1186738027_thumb.jpg
Edited by -SKYLINE-
https://www.sau.com.au/forums/topic/180336-skyline-parts-rb26-rb25-rb20/
any chance of a better pic of the coilpacks? Im not 100% sure if they are the same as a 25 or not... if they are i'll take em.
well i had some splitfire packs out of my RB25 and took them out and put them in my new RB26. On the Splitfire box they say they will fit RB25det RB25de RB26dett
best i could get with out being fuzzy
revise the prices on the guages. The sender alone costs 180 and seeing as there guages are discontinued, its goin to be very hard to get them senders lol
make me an offer then. These gauges are still available from stores.
What Spec is the Cooler?
Or dimensions?
600x300x76
GReddy M-Spec. Very similar to the VSPL but slightly less flow. Wouldnt notice any different unless you had a nuts engine.
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
