I'll start off with mods:
RB20DET
R33 S1 Turbo (R32 actuator)
JJR FMIC
GFB Stealth FX BOV
POD
When I was running my standard R32 turbo, FMIC and POD, on my boost gauge it would read 10psi with standard BOV. Once I fitted the GFB one, boost rose to 12psi all the way to redline.
Now that I have fitted the R33 turbo with R32 acuator (no boost controller whatsoever) boost under full load at about 5-6000rpm hits a peak of 15psi.
I've tee'd the acuator hose into the hose that comes off the crossover pipe to the bov. It's about 30cm long and I've got a feeling this might be a cause rather then the standard r32 acuator as it wasn't a problem before??
Cheers.
https://www.sau.com.au/forums/topic/180595-r32-acuator/
he has already said what causes it..
it's the extra long hose to the actuator.
if it was a short hose from the actuator to say the comp cover like the stock R32 turbo or even to the intercooler pipe near the turbo, boost will be around 11-12psi as per stock setup.
now go get a remap of the stock ECU.
I think CEFFIE on these forums should do this for a living.
he know's the RB20 well and can get some decent numbers form them.
free plug for CEFFIE
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3283542
it's not the culprit. Like I said, I have 120 cm of vac line between my actuator and the boost source. Runs 11 psi day in day out
We posted at almost the same time..
I think it has something to do with my BOV because checked clearances of the acuator before fitment. I'm going to put stock BOV on and see what reading i get.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3283823
Definitely nothing to do with bov.
Everything to do with boost control. That being the boost source, actuator, the flapper and the dump. My bets are on the jjr dump fouling with the wastegate slightly.
The rb20 turbo's are known for falling over at high rev's; they drop boost.
The rb25 turbo's are just that little bit bigger on the compressor side so they require better wastegate flow to keep boost under wraps.
A bloke only the other week had the same issue with his split dump. It wasn't until he removed the dump that he realised the dump was indeed preventing the wastegate from opening fully.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3284174
If you read my previous post, i dummy fitted the r33 turbo with r32 acuator to the dump prior to installation and it didnt foul.
I even ran the dump on the standard rb20 turbo with rb20 acuator without and problems. Held 12psi the hole time.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3284447
You said checked the clearances of the actuator. The actuator is not the wastegate :D
With regards to the rb20 turbo; smaller compressor; they are known for falling over at high rpm so its unlikely you would see it overboosting easily.
The rb25 turbo on the other hand is different kettle of fish, flowing more air making more power more air has to be bypassed.
I really think you should go back and have another look at the dump/wastegate.
Wire the wastegate completely open and see if it still makes boost up top.
Obviously it will be as laggy as shiet but up over 5500-6000rpm you will see it making some boost; how much boost 15psi? 6psi? If it still makes the 15psi then its 10000000% the dump fouling the wastegate. Even slightly fouling can cause problems.
Long runs of hose to the actuator creates issues with boost spike.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3284493
Ok I'll check this this arvo/tonight. Can I disconnect the actuator pipe and wire the flap open? Should I then see the regulated 10-12psi at 5-6000 rpm?
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3285567
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
