I'll start off with mods:
RB20DET
R33 S1 Turbo (R32 actuator)
JJR FMIC
GFB Stealth FX BOV
POD
When I was running my standard R32 turbo, FMIC and POD, on my boost gauge it would read 10psi with standard BOV. Once I fitted the GFB one, boost rose to 12psi all the way to redline.
Now that I have fitted the R33 turbo with R32 acuator (no boost controller whatsoever) boost under full load at about 5-6000rpm hits a peak of 15psi.
I've tee'd the acuator hose into the hose that comes off the crossover pipe to the bov. It's about 30cm long and I've got a feeling this might be a cause rather then the standard r32 acuator as it wasn't a problem before??
Cheers.
https://www.sau.com.au/forums/topic/180595-r32-acuator/
he has already said what causes it..
it's the extra long hose to the actuator.
if it was a short hose from the actuator to say the comp cover like the stock R32 turbo or even to the intercooler pipe near the turbo, boost will be around 11-12psi as per stock setup.
now go get a remap of the stock ECU.
I think CEFFIE on these forums should do this for a living.
he know's the RB20 well and can get some decent numbers form them.
free plug for CEFFIE
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3283542
it's not the culprit. Like I said, I have 120 cm of vac line between my actuator and the boost source. Runs 11 psi day in day out
We posted at almost the same time..
I think it has something to do with my BOV because checked clearances of the acuator before fitment. I'm going to put stock BOV on and see what reading i get.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3283823
Definitely nothing to do with bov.
Everything to do with boost control. That being the boost source, actuator, the flapper and the dump. My bets are on the jjr dump fouling with the wastegate slightly.
The rb20 turbo's are known for falling over at high rev's; they drop boost.
The rb25 turbo's are just that little bit bigger on the compressor side so they require better wastegate flow to keep boost under wraps.
A bloke only the other week had the same issue with his split dump. It wasn't until he removed the dump that he realised the dump was indeed preventing the wastegate from opening fully.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3284174
If you read my previous post, i dummy fitted the r33 turbo with r32 acuator to the dump prior to installation and it didnt foul.
I even ran the dump on the standard rb20 turbo with rb20 acuator without and problems. Held 12psi the hole time.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3284447
You said checked the clearances of the actuator. The actuator is not the wastegate :D
With regards to the rb20 turbo; smaller compressor; they are known for falling over at high rpm so its unlikely you would see it overboosting easily.
The rb25 turbo on the other hand is different kettle of fish, flowing more air making more power more air has to be bypassed.
I really think you should go back and have another look at the dump/wastegate.
Wire the wastegate completely open and see if it still makes boost up top.
Obviously it will be as laggy as shiet but up over 5500-6000rpm you will see it making some boost; how much boost 15psi? 6psi? If it still makes the 15psi then its 10000000% the dump fouling the wastegate. Even slightly fouling can cause problems.
Long runs of hose to the actuator creates issues with boost spike.
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3284493
Ok I'll check this this arvo/tonight. Can I disconnect the actuator pipe and wire the flap open? Should I then see the regulated 10-12psi at 5-6000 rpm?
https://www.sau.com.au/forums/topic/180595-r32-acuator/#findComment-3285567
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
