ohh well any one have same CD changer like I posted earlyer? maybe seen @ cash converters some where.. I love to know... I polly buy exact same one...
Yo dude, i have a CD Changer tha came with my car. Its been just sitting in my shed, it wasnt hooked up when i got the car.. just sitting in a box when i bought the car. Your quite welcome to have it for free if you pick it up. Dunno if it even works tho.
Also open to any1 else if PVA doesnt want it
EDIT: just found out that this is over 2 years old. dang.. but if any1 still wants it
jeez joe dont u think its time to get over it? it was more than 2 years ago lets not live in the past :D
wats with the old threads ppl
I let it go 2weeks after it happen but some ideot is bringing back old threads.
for the record I am not happy with all this shit, and PMed prank about it.
Where is WA mods ffs.
  • 4 months later...
Majority of my threads coming back alive, I dont know why? I dont even post here much anymore...
I have feeling that someone is screwing the system here :(
I blame the government. Pricks.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
