Hey Anton
Sarkis' 'group buy' did go ahead in a sense, but it wasn't really a group buy as such. It was pretty much - those are the prices, take your turbo down there and get it done at your own will.
I knew a few people who went ahead with sarkis' buy who borrowed housings off me so their car wouldn't be off the road for as long
I saw some of the turbos that came back and they are a great piece of work.
Nice work organising this buy. I might be in touch with you/john shortly - got a some projects that I might building
hey Chris, yeh just thought that if we do it this way we can get people together and get it at a discounted price. i might buy one of your vg30 housings of you, but ill see how things go. He offered to do it for $1250 straight up and $1100 if we went as 5 and did it. If we get 10, he might even drop it to $1000, which is a good price IMO
do these use the stock oil and water lines, as they are? or do they need to be modified?
is there any chance that in the group buy, there would be an option for the ball bearing version and just pay the difference on top of the journal bearing group price?
if so, what price for bb?
Edited by Munkyb0y
Monkeyboy, if these are like the precision turbos ball bearing ones (should be the same - theyr'e both garett catridges), then john supplies you everythign you need - washers, new banjos, banjo ends, gasket for turbo, oil drain gasket - everythign you need.
Monkboy: i know you use the existing oil and water lines, but ill confirm if they need to be modified at all. irrespective, if they are required to to be modified, all work is included in the price. Ill also try to find out what price he can do for the ball bearing and get back to you tonight.
Sexypete: so does that mean your in mate?
hey i just got a precision high flow ball bearingturbo for my r32 and its really good. i have some minor issues with my car but its definately worth it. the car is making 16psi at 4000rpm. but i did have to get new lines made up for my turbo and it would of been better if i was to buy a hks gtrs. if you are going ahead with this please make sure that it does truly bolt up or all the modifications required are listed.
I'll explain based on the ball bearing model. Like i said above, as they use a garett catridge, the bajo bolts are different sizes.
John supplies new banjos for the water and the oil.
The new oil banjo works with the stock oil lines.
The new water banjos use a different size water line end. John supplies this.
For those people getting the turbo installed by a workshop, this will be no difficulty for them.
For those people isntalling it themselves, there are a few different ways to do this. Get the new banjo end tig welded onto the stock lines to replace the stock sized end. This is perfect - will look like stock, be as strong as stock. Most places will charge about $20-30 for this because its only 2 welds.
Alternatively, you can take your lines off, and take them down to pirterk and get some braided lines made up - costs about $80 each.
I prefer to just get them tigged
sorry, i dont have any dyno sheets, but if you wanted a ball bearing, you'd be looking at at least $1500. Also to save youself hassle, if you can provide your own lines, they will be modified to fit straight back on
    • Thanks for posting, your engine bay looks tops. I'm fairly sure you posted the wrong video though, I think you were supposed to upload the one from your "private test road" where it's banging off the limiter with the gate open?
    • This is something to be careful of. I did a bit of digging on the NM35, as I spend a lot of time on near brand new cars and CANBus related stuff, which uses the same "OBD2" plug for a fair chunk of making my life easy. The NM35, does NOT support OBD2. The data pin is actually on Pin3, which is a manufacturer specific pin, and requires Consult3 to connect to the NM35. Your low voltage, is either because the NM35 doesn't have 12V to the constant power pin on the J1962 (OBD2) connector, OR, it is attempting the standard comms, (CanBus, K Line, etc) and can't see any voltage on those pins. Some people have had success accessing SOME data from the vehicle on OBD2 specification, using a module that supports KPW. My assumption, like Duncan has stated, it will likely actually be JOBD, where there is some cross over with the OBD2 and JOBD standards. Note, lots of "OBD2" dongles, do NOT support KPW, which is what you need for a lot of Japanese vehicles of this era (And even up until recent years!), EG, Subaru, Suzuki, etc.    The end of this thread is probably worth a read, as some people did find a way to get a display up in the NM35 recently, looks like someone implemented all the stuff needed to make it work. (The right protocols).
    • Depending on the purpose of the car, and how much more fabbing you want to do, and what clearances you have, you could look to raise the motor, which will raise the front diff up. Likely would mean altering the chassis rails etc etc, hence the more fab work you'd need to do. However, this can create issues, not just in clearance with everything fitting under the bonnet, but you've also raised a LOT of weight up in the car, and this will DEFINITELY alter handling characteristics (But, so will how much weight you've already added to the front end). You'll also have to deal with the fact the gearbox to rear diff is now out of alignment too for the tail shaft, and alter the angle of the diff, or deal with a bit of potential vibration. Raising the motor an inch up, is effectively the same as making the whole car sit higher by not lowering it as far. So one inch higher motor, theoretically means you can drop the car an extra inch lower, and maintain the same angles in the CVs. Again, depends on the purpose of the car. If it's a just cruiser on the street car, maybe won't be an issue. If it's meant to be a time attack car, I can see you not wanting to raise the motor. This is just for you to ponder as an idea.
    • Have you not seen geospy.ai? It can now give GPS co ords to within a metre from a photo, even if it's a random photo you take inside. Supposedly at the moment only the government/law enforcement has access to that... Supposedly...
    • I've got the rear ones, they're certainly beefy. I need to take them to my driveshaft guru to check over, he's very fussy about the quality of components so I'll let you know if they are made of cheese by a blind man.   Are you in Australia? A mate just had a set of EN26 shafts made for his K20 Lotus by our fabricator which were quite cheap (compared to Driveshaft Shop) so if you can procure the CV's and draw what you need he'd make them for ~$800 for the pair.
