Hi i recently purchased an apexi power fc for my series 1 r33 its brand new with hand controller i set it up as per the manual that came with it, when i start the car it starts and idles very roughly and it only running on 4 maybe 5 cylinders and is poring bulk fuel into it (all i can smell is fuel) from the exhst. I put the same ecu into my mates car a ser 2 and it runs perfect i can not work out whats going on anyone got any ideas?
Thanks lars
hey man, i had similar probs with mine n it was just the connections on the loom plug bolting to computer, wasnt 100% straight, the reason your smelling fuel is because its not being burnt by 1 or 2 of the cyls so is going into exhaust, try take plug off and retighten it and make sure its on straight to eliminate that...cheers and good luck
etc, version
what do you see?
etc, sensor sw / check
anything highlighted in black?
what do you see?
is the engine check light (orange) on when you have the problem?
have you performed the self idle learn procedure properly ?
I think it was version 5 for rb25det
nothing high lighted in sw check
engine light was on at first due to boost control on turned it off no light
the light is off when its running i did the idle self learn properly
car just runs on 4 cyl runs perfect on mates ser 2.
Thanks
etc, version
what do you see?
what do you see?
Check the plug again and make sure the bolt bottoms out. All bets are on the plug not being 100% true and in as with some cars the bolt can be very stiff to do up making you think its done all the way up but its not. Tripple check. :wave:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
