no way can i see anything there is just too much shit in teh way and doesnt look very easy to pull it all off.
il go have a look at that exhaust number but in the mean time the actuator has a stamp on it that says 242x02 in black writing and its stamped ASN79 or somthn
4513 pretty sure. the 4, 5 and 3 is a definate confirmation but the 1 sort of looks like a V not sure, thats teh best angle i can get.
really looks like a V but not sure.. so i guess if it was that makes it a 45V3 which yeh is off a rb25, but there is a 45V1, 45V2 as well isnt there? whats the dif between them
Edited by YEHBOI
on what engine?
on an RB25.. yes.. it's too much.
on a smaller rb20 it should be just about as much as you'd want to put through a ceramic exhaust wheeled turbo.
all the pics you've posted have had 20V seca in the name so you could be putting this on a 4age in which case, I've seen people put 17+ through that turbo on those engines.
the RB25 is 500cc larger in capacity.
it can push out x amount more air so to speak.
so people say that the max safe boost setting for a stock R33 gtst is about 10-12psi.
and on a car that is 500cc smaller in capacity, it can handle more boost to put the same amount of strain on the turbo as it does on a lower boost setting when on the RB25.
Also, the RB20 has lower compression than the RB25 which also means more PSI to bring the power/heat to the same levels.
f*k that was a messy post.
Edited by GTST
its on my R32 GTST - RB20.
why the psi differences? is that due to the fact a RB25 puts out alot more exhaust heat than the RB20?
At 10PSi on a 2.5Litre, compared to a 2L, you're putting through more air. Which means turbo spins faster, which means more heat in the turbo.
Well said. :/
Makes sense when you say it that way.
Thanks,
Abu
which also means more power but that's a different point.
on one of my RB20's I bolted an RB25 turbo to, I had the usual mods except FMIC.
with the exhaust and filter being free flowing, and no boost control, the stock car would boost to 11psi. (stock is 10)
Once the RB25 turbo went on and I used a boost controller to bring it to 11 psi (I used the stock actuator instead of the rb20 one so it had 6psi stock), I put it on a dyno and it made 153rwkw.
I think a stock R32 makes around 110rwkw.
an RB25 with stock turbo at 10psi (if it isn't missing and spluttering like a shitbox) will have around the 170rwkw.
an RB20 with stock turbo at stock 10psi but with intake and exhaust mods will have around 130rwkw.
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
