no way can i see anything there is just too much shit in teh way and doesnt look very easy to pull it all off.
il go have a look at that exhaust number but in the mean time the actuator has a stamp on it that says 242x02 in black writing and its stamped ASN79 or somthn
4513 pretty sure. the 4, 5 and 3 is a definate confirmation but the 1 sort of looks like a V not sure, thats teh best angle i can get.
really looks like a V but not sure.. so i guess if it was that makes it a 45V3 which yeh is off a rb25, but there is a 45V1, 45V2 as well isnt there? whats the dif between them
Edited by YEHBOI
on what engine?
on an RB25.. yes.. it's too much.
on a smaller rb20 it should be just about as much as you'd want to put through a ceramic exhaust wheeled turbo.
all the pics you've posted have had 20V seca in the name so you could be putting this on a 4age in which case, I've seen people put 17+ through that turbo on those engines.
the RB25 is 500cc larger in capacity.
it can push out x amount more air so to speak.
so people say that the max safe boost setting for a stock R33 gtst is about 10-12psi.
and on a car that is 500cc smaller in capacity, it can handle more boost to put the same amount of strain on the turbo as it does on a lower boost setting when on the RB25.
Also, the RB20 has lower compression than the RB25 which also means more PSI to bring the power/heat to the same levels.
f*k that was a messy post.
Edited by GTST
its on my R32 GTST - RB20.
why the psi differences? is that due to the fact a RB25 puts out alot more exhaust heat than the RB20?
At 10PSi on a 2.5Litre, compared to a 2L, you're putting through more air. Which means turbo spins faster, which means more heat in the turbo.
Well said. :/
Makes sense when you say it that way.
Thanks,
Abu
which also means more power but that's a different point.
on one of my RB20's I bolted an RB25 turbo to, I had the usual mods except FMIC.
with the exhaust and filter being free flowing, and no boost control, the stock car would boost to 11psi. (stock is 10)
Once the RB25 turbo went on and I used a boost controller to bring it to 11 psi (I used the stock actuator instead of the rb20 one so it had 6psi stock), I put it on a dyno and it made 153rwkw.
I think a stock R32 makes around 110rwkw.
an RB25 with stock turbo at 10psi (if it isn't missing and spluttering like a shitbox) will have around the 170rwkw.
an RB20 with stock turbo at stock 10psi but with intake and exhaust mods will have around 130rwkw.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
