My car has a very strong petrol smell when idle, its not leaking into the cabin, but if i am just starting up the car and have the door open, or idle at a drive through with the windows down.. it pretty smelly. the exhaust is not smokey or anything :S
is this normal..
its my first car so ive got nothing to comare it to but mums magna and dads astra dont smell this much.
https://www.sau.com.au/forums/topic/181257-strong-petrol-smell-when-idle/
is this normal..
I am driving a NA S2 R33 as well, experiencing similar problems when im idling especially when the engine is cold...till today, i cant figure out wats wrong with it.....didnt notice any leaks from the injectos though
hows ur consumption like?
btw nice S2 u got there
thanks, consumption is excellent about 450km per tank. and yeah i must agree when its cold its a lot worse. i have no modifications except a muffler tip.
it doesn't seem like a big problem, i can live with it. just was curious to see if any other people get the same thing
Mine smells only on cold start, once its warm you cant smell a thing
I presume because the ecu runs it rich while warming up
I had leaking injectors also but i got that fixed, before that the petrol smell was always there.
is the smell in and around the engine bay? or unburnt fuel coming from the exhaust?
if it's the later then you're just running rich idle
it is the later
very much from the exhaust
Mine does it too, S1 33 n/a, when i hop out i sometimes get a huge wiff of it. usually near the driver side door i smell it more..
I only get like 300k's a tank prob the way i drive though and alot of little trips
yeah my old series 2 used to do that, my new one doesnt, both n/a
it used to stink like rotten egg's/petrol.
no idea what it was as my car was completely stock with under 100,000k's...aparently
i put on a 3 inch cannon onto the stock system and this made it 100 times worse. i think the ecu makes the car run rich to protect it from something..as you can tell i dont know much about cars.
i get around 350k's to a tank....i think.
at least i know im not the only one.
    • The front prop shaft from my GTR had very notchy unis, which obviously needed replacement but unfortunately uses the (usually) non-replaceable (staked) type.     A new shaft is something like $2K plus shipping from Japan.   I wouldn't even bother asking the local Nissan spares dept.     Rang Hardy Spicer but no go, which surprised me a little.     There's a place over Dandenong way that would make me a 'performance' shaft but un-necessary in my situation.   They claimed to be getting the equipment in to replace staked unis but couldn't give me a timeframe.   Anyway, long story short, found a place to do the work just 5 mins from me: https://knoxdriveshafts.com.au $420 (cash) and about a week later I have my driveshaft back.   Price includes balancing. Owner is a one man band working out of a shed in his backyard but from what I could see he's very well setup with some expensive equipment.
    • Thanks. That's what I was after. One of the kits, the o-ring side is too big diameter. The other kit is a plate with a o-ring to seal and the hose connection offset.
    • Are you using the factory rail?  Is there any reason you don't want to use one of the two you already have, they don't have to attach to the fuel rail directly.  If you 100% must have a FPR that directly bolts to the fuel rail, you could get a Radium setup. I use a radium fuel rail and the direct mount regulator, it is quite a sexy setup.
    • https://www.google.com/search?q=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&sca_esv=6710113de42d5150&source=hp&ei=GhPbaNHfNZeinesPyPqEiQc&iflsig=AOw8s4IAAAAAaNshKnLkjQGMWYT5EyclmXEJm8ZXSWDb&ved=0ahUKEwjR1JOCjf-PAxUXUWcHHUg9IXEQ4dUDCCE&uact=5&oq=adjustable+fuel+pressure+regulator+nissan+fuel+rail+adapter&gs_lp=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_EFhqEHecdnjv2SBwYyLjU1LjGgB7XnArIHBjAuNTUuMbgH4UXCBwgwLjUuNTEuMsgHiQI&sclient=gws-wiz
