hey guys, dont you just hate it when you are driving through a car park and there is a smart ass that just decides to walk in front of ya and doesnt get out of ya way. as soon as i pass em i wanna give him/her a lil punnishment hehe. so i am asking are you able to have some type of purge without having to use nitrous??
https://www.sau.com.au/forums/topic/181338-purge/
Get caught with your nitrous kit attached on the road here in WA and recieve a fine and a red sticker.
I can't see a purge kit scaring many people. Have you seen one activate it's definately not the 4th of july. Try a set of truck air horns or a starter pistol plumbed into a solenoid if you want to be a weirdo.
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295675
Get a CO2 Purge Kit on the front of your intercooler, that way you *might* scare parking lot wallabies and it will also serve a purpose (condenses the air going into the intercooler).
Or if you really want to scare them plow right through them!
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295715
Bee*r Rev Limiter + Lotsa revs = smart ass needing new underwear.
what he said... FTMFW
had this guy go to us at the lights "your back wheels are going ot fall off, im like na thats the major negative camber and he disagreed and thought we knew what he was on about" he got highest stage bee*R with his window open.
he well shat.
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295834
One of these suckers will do the trick
http://www.youtube.com/watch?v=FONe--EjCpc
HAHAHAHAHA that is f***n funny, yeah id say go with an air horn. I bought one from motorquipe in carousel for 25 bucks. . . . Just shake, aim and press the button. . . .Very loud and cheap to buy, and fun to scare people haha
Edited by Daniel R32
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3295965
kekeke when i had bee*r i did that to some lady walkin on the road blocking the way when i got a chance to go pass her i revved it up and loaded past her and then bang bang bang she shat herself
mmm good times good times :P
https://www.sau.com.au/forums/topic/181338-purge/#findComment-3296014
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
