  • Replies 95
Posted Images
yes but air bags . as i removed the inner airbags onto my car after my accident...
So do you want to sell the steering wheel?
If its in good condition I'm interested. I dont care about it having no airbags.
  • 4 weeks later...
Hey champ,
I PM'd you ages ago - the part you supplied me is not the part I'm after. Could you reply to me so we can arrange this to be corrected, I need the vent in the post above - not the duct that is behind which you sent me
Thanks
Edited by Jaron
i have it in autoo.. not sure if auto and manual are the same for the plastic things.
thanks
john
Hi mate,
I'm after the plastic bit around the gearstick, the bit that holds the ashtray and lighter.
Do you still have it?
Cheers
