Ok, so my stag is FINALLY going on the dyno tomorrow for a tune. What's the guess of RwKW (getting done at UAS in Sydney who only have a 2WD dyno) ??
1997 RS Four V
Mods are:
BOS 3" split dump pipe
Catco Metal Cat
Trust Power Extreme 2 cat back zorst
K&N Panel filter
R34 Intercooler
GTR Fuel Pump
AFC Neo computer
SITC computer
Turbotech mechanical boost controller (expect set to 10psi)
Full service has been done with new filters for everthing, spark plugs, timing belt and water pump so running sweet as a nut.
The prize will be bragging rights for knowing your stagea power figures :D:)
Stu
https://www.sau.com.au/forums/topic/181590-kw-bingo-guess-the-power-output/
I am running 4wd, but Unique Auto Sports only have a 2wd Dyno so they will drop the driveshaft out. I am hoping for 150awkw, so would have to be 160 or so rwkw I guess.
Will be a big improvment over how it is now though, which is the main thing :)
What time are you going there, Stu? I live just around the corner from UAS and have also just booked my car in for some work there (for early next week), so I might come along, meet you and see how your car runs...
you can just undo 4 bolts and drop the front driveshaft, but you will lose about 10kw.
Less power transferred, is less power lost.
You will not loose power going to RWD, you would expect to gain a minor minor amount, being its not fulltime 4WD.
i think the SITC will make it hard to crack 200rwkw with less load points but who knows maybe we can go around and drop the temp probe in to a nice hot cuppa and crack 220rwkw.
EGA4IT made just over 200rwkw with an RS4S and powerfc with similar mods on the same dyno as a comparison.
OK, the results are in and the winner is .....
Tangles :(
Max power 152.9Kw at the rears running just under 10psi. This is a Series 1, not neo motor by the way. And an auto :P
I will scan the printout at some stage but Andrew at UAS did a nice job on the tune. Power deliver is smooth all the way through with no dips and boost holds constant the whole way. Go the $30 Turbotech controller :) A/Fs are around 12 or just under too so nice and safe.
They did not tune the SITC this time as worried about detonation with the side-mount intercooler and I am driving to Brisbane this weekend so I think they are playing it safe. With a FMIC, exhaust cam gear and some more tweaking on the afc and sitc I would hope to see another 20Kw. All in all pretty close to what I was expecting so can't complain about that.
Goldzilla ... sorry I missed your post as my PC at home is dead and I went down there first thing this morning. Is yours the green one coming in for a 'trial fitting' next week ?? :O
Speaking of fitting, the Power Extreme cat back zorst needed a fair bit of manipulation to line up unfortunately. I guess that is the price of mixing and matching local dump pipe and cat with jap exhaust. A word or warning for others I guess, the BOS dump and Catco cat may not line up exactly like factory
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
