I will be there with both cars. R32 is now roll caged, has new OS giken R3C triple clutch and new OS giken box with HD input shaft. Trust 6-speed dog box is out to get its yearly inspection. Soon will have new tune with the 1000cc injectors and dual bosch fuel pumps done on the 25th.
V-spec will keep its current OS giken box and tune, and will have 2nd new carbon triple as INTUNE totally f*cked it up, hence why my last attempt the car went backwards. 12.4 and 12.9 I was pretty pissed off. I shouldn't have changed away from Glen and MarK at brake and clutch. Mark knows his stuff, he is really knowledgable. I'm paying for it now.
They better let me run the R32 as my 10 second passes were at a test and tune meet, so technically they shouldn't have kicked me off until I ran that time at a bracket meeting. Watch CADRA be total wankers if the car does 140mph +, it's going to be a total shitfight. If they change their mind on passing my cage then they can forget me going out to drag race ever again. It seems like it's fine for the imports to race as long as your not beating the main V8 players, if you do, then they get sooky. Really is a bit of a red neck attitude out there and I don't think they take the Japanese cars seriously at all.
I think it's more a case of the only cars running the passes that are in the 10's or better are the purpose built cars so for someone in a street car to get there has probably raised a few hairs on the back of peoples necks. Just keep getting faster BK and try do everything to the ANDRA regulations rather than CADRA. If it's at national spec then there can't be any arguement. If they do pick on something I would assume it would be for the safety of yourself and the other racers. I can understand what you are saying about running that time at a test and tune though, it should have been left until a bracket meeting before something was said. Test and tune is exactly that, testing your equipment and making any changes required.
See you out there when my new gearbox is in.
They do make up their own rules though. I can't find anywhere in the ANDRA book that says you need to secure your oil filter, and that is one of the first things they pick on you about. If you can find it tell me where and I'll stand corrected. Anyway are you going to enter the 1320x event ? If so you'll need a four point harness at SFI 16.1. ANDRA is 11's for 4 point but this meet they are inforcing 11.98 OR 110 MPH. That's you, me, ozzy, fab, craig - all over 110mph. Pretty silly I think. I'll see you guys out there after Finke to stir the CADRA pot !
Edited by BK
Oscar, how the hell did you manage the 11.7 in RWD ? That's pretty good bro. I dunno when I'll be back out now after buying this house. I didn't have any front diff or cv shafts installed anyway. Was going to bring the white car but I had to work. Blue car is still a while off being fully ANDRA legal. After looking at the calendar I'm going to aim for Aug. 16 with both cars. White car just needs a bit more of a break in with second carbon clutch and to sort out boost control issues. As I told you the blue car has got some oil and water leaks to be addressed.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
