As the title suggests I have got a whining noise after doing a cam belt change, I've removed it and re installed a couple of times. I've also changed the tensioner and idler, all genuine parts. I've eliminated all the other belt driven parts by leaving them disconnected.
Could the belt be too tight or is it something else?
Cheers
did you use genuine nissan - I hear that some of the guys on here have trouble with the gates being a bit noisier.
Its a bitch because if you dont get it right the first time you have to undo the crank bolt again to get the timing cover off right?
Edited by benl1981
Ok it's seems odd that it's over tensioned as it has about 5mm play either side on the intake side and a very small amount, almost none on the exhaust side...
Could it snap if over tensioned, although it has some play in it?
Edited by Japtastic-UK
LOL you can keep the bloody ashes :D
I used the technique in the FAQ's for tightening so yes I used the spring, it is really annoying I think I have it tensioned right, to be honest I wouldn't feel right losening it off as it seems right, not sure what to do :cheers:
thats hard to say. I know with mine it was a bit like - "feels about right" aswell as following the procedure.
I thought I did mine pretty tight but no whining. I know other cars weve had done at the mechanic had a different engine note after the cam belt change - i.e. a bit more whiney :cheers:
You used nissan belt..i see. Not sure mate.
You could take it to a mechanic to show them the tension. Just take the top cover off outside the garage after youve showed them the noise its making... if youre really concerned.
Edited by benl1981
Well it drives perfectly, just taken her out, noise seems to be getting quiter already? I have got a a slight bit of play in both my exhaust and intake pulleys though which I didnt notice before but I may just be being too fussy, are they supposed to be straight as a dye or is a small amount of play acceptable?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
