I was going to try here.
http://www.plmsdevelopments.com/realtime.shtml
when i can find a reasonably priced z32 ecu that is.
Are these the same guys that you've tried.
If so doesn't look to promising.
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3330794
Do a google search, live edit is free however all of the other hardware is not...
It is morre expensive than the nistne setup, and not as good.
so i'll keep waiting also.
on a side note, anyone have or know where to buy an z32 ecu at a decent price. I mean $400for a 16-17 yr old ecu seems a little rich.
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3332978
We've now got working R33 tuning boards available, will have the Nistune update from Matt this week to see how the nistune software goes with the RB25, can't wait...
I'm using NRE from the same guy who wrote LiveEdit but full real time map tracing and emulation...
R33 Remap - Example
Standard R33
FMIC
040 Fuel Pump
3" Turbo Back Exhaust
HyperGear TR43
STD AFM
STD Inj
STD Air Box
Remapped R33 ECU - 45 mins of dyno time
More to come with upgraded injector and afm
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3335522
At the moment they are quite expensive, and yes quite difficult to install, would only recommend advanced electronics techs attempt this, need smd experience and equipment... I'm still trying to work things out regarding fast turnaround of supply and install with base maps...
Edited by Dr_Drift
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3335675
Hey Guys
Good to hear news is spreading.
And sorry for the no reponses to email. Just found out last week that AAnets mail server has been really dodgy and not passing on emails... and I just thought it was getting a bit quiet until Pete L told me customers were able to contact him through his site.
Not happy but not much I can do now until they fix it!
Please contact me [email protected] in the meantime if you wanted to know any thing about the boards or place an order etc.
thanks
Matt
https://www.sau.com.au/forums/topic/181930-nistune/page/2/#findComment-3362228
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
