Hey guys I have a question. I am keen to have my ecu rechipped, with nistune
but I also have a ecutalk v2 display, I was wondering if the 2 were
compatible and if my ecutalk display would still work after having nistune installed.
I have done several searches on google and various forums and I have been unable to find any info. :laugh:
any help would go a long way thanks.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5170133
hey ppl, might be a silly question but does nistune use an afm?? eg, if wanting to upgrade to a z32afm, is it needed or not??
cheers
If someone was to make a map sensor replacement module for the nistune/stock ecu would there be much interest in something like this?
It can certainly be built but if theres no interest I won't bother researching it.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5170937
already looked into this. Should be very simple, read in map sensor values read in air temp sensor add correction factor output 0 - 5v signal back to the ecu. Main thing would be the need for a complete retune of entire map, but this effort could be minimized with extensive logging of afm and map values in parallel(Similar to the holden MAFless tunes). I believe some one has also used TPS as loading on an NA Vl commodore using nistune
Edited by Crans
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5170950
Yep if you did no correction and just made sure it was linear in the range used from 0-5v it would still be very easy to tune.
Ah so many ideas and so little time. Need to get my car running and buy a decent oscilloscope so I can finish the VCT controller I've been carrying on about.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5171022
I have done several searches on google and various forums and I have been unable to find any info. :P
I can confirm my ecutalk v2 display (and 1.3.x windows software) work fine in my nistune'd R32 GTR. love the new 2.02 firmware with the user-configurable alarms and am gagging for the eventual logging to micro-sd.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5173040
hey guys i just bought a r32 gts4 and was thinking of doing the nistune upgrade for the ecu, but i want to change it to a manual as well. would i need to get a manual ecu or a gtr ecu? or would it be fine once the daughterboard is installed? don't wanna upgrade then find out i need a new ecu lol.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5175332
the daughterboard can be reprogrammed for different ROM images. bascially we can put a manual program in auto ECU no problems
GTR ECU is completely different you wont be needing that in a GTS-4 unless doing an RB26 transplant with twin AFMs
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176244
Are the daughterboards for 32GTSt and 32GTR the same?
Reason I am asking is I am looking at Nistuning my 32gtst but if I max out my z32 afm, I am wondering if I can swap the daughterboard in to a 32GTR ECU and get a GTR image loaded on there ? (and then run a GTR engine harness and twin afm's)
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176335
Wanting to buy a board and tunning package to have a play with.
Any one else using it? What do you think f it?
How do you buy it? Ive sent emails no one answers
I bought and installed my Nistune daughterboard direct from the guys that make it.
It is installed in my S13, and was tuned by Mark @ MRC dyno in castle hill. I haven't had any issues with it, and for the price i think it is an excellent option.
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176539
got a question for ya's
i have a type 4 daughter board in my r34.
I know that the daughter board has its own EEPROM that we can change the values in while tuning in nistune software. And the original ECU's EEPROM stays unchanged, we just tell the ECU to read from our new EEPROM. Is this correct?
If this is correct, could i tune my car on pump fuel 98, then take the hex file from the daughter board's EEPROM and burn it into the original ECU's EEPROM, then re-tune the daughter board as usual on e85 fuel? then i just have to run a couple of switch wires from the jumper pins on the original ECU to the dash and i have instant capability to drive on either fuel.
But is it even possible to burn a new image into the original ECU?
and can anyone see any major flaws in my idea?
https://www.sau.com.au/forums/topic/181930-nistune/page/11/#findComment-5176589
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
